Old 01-06-2011, 03:21 AM   #21 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
There's always the glossary: http://ecomodder.com/forum/showthrea...e-ii-3505.html
It happens to be linked on every page of the forum
Old 01-06-2011, 04:08 AM   #22 (permalink)
The PRC.
Except - every reference to coasting in that thread also says engine off. Whats a poor ecomodder to do ?
Old 01-06-2011, 06:53 AM   #23 (permalink)
Dartmouth 2010
SVOboy's Avatar
You could always suggest revisions there within the thread so we could update or expound upon confusing terms.
Furthermore, coasting is generally accepted as being out of gear, ie, neutral, regardless of engine state, and I think that's considered assumed by any discussion in the glossary.
Old 01-06-2011, 10:59 AM   #24 (permalink)
The PRC.
I forgot the at the end of mine as I'm into mischief...
However if you search for 'coast' in the link, each on specifically says engine off, or engine shut off I think.
Heated Fuel bennelson EcoModding Central 81 03-10-2022 11:28 PM
idea, 4 cylinder to 2 cylinder engine conversion saand EcoModding Central 152 01-02-2016 03:33 AM
Some Hypermiling techniques denounced by AAA Lazarus Hypermiling / EcoDriver's Ed 135 04-17-2011 04:07 AM
Mer-Chevy Project: Biofuel 40mpg Pickup bennelson EcoModding Central 128 07-27-2010 06:15 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
