11-13-2013, 04:53 PM
#11 (permalink)
Well - if the Germans could power at full size U-boat submerged for 24 hrs. on batteriet during WWII, (and later for that matter) a truck should not be impossible. (Water makes more resistance than air)
Pelenty of room for batteries, and a rigid frame, but the wight will reduce load capacity somewhat.
11-13-2013, 05:35 PM
#12 (permalink)
Tesla truck?
Model S is a Sedan...
Model X is a Crossover...
So a Truck will be a Model.... T?
Tesla is going to compete against Ford with a Model T?
Really?
The Following User Says Thank You to darcane For This Useful Post:
11-13-2013, 07:51 PM
#13 (permalink)
Spaced out...
Originally Posted by darcane
Tesla truck?
Really?
NICE!! Talk about the world coming full circle lol
Seems like an interesting idea, Maybe the batteries will be packed under the hood much like an engine, and the rear will be special built with the motor directly attached to it...thus giving a better weight distribution since the motor will probably weigh as much or more than a new 6speed auto trans.
Either way, don't think tradesmen will adopt it quickly, but since most trucks sold in USA are NEVER used to haul much of anything, I'm sure the suburbs will love an electric truck.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
11-13-2013, 07:55 PM
#14 (permalink)
White Whale - '03 Chrysler Town & Country mini van all white
Speaking of luxurious; what ever happened to the Luxury Zap PU?
11-13-2013, 09:55 PM
#15 (permalink)
Tesla will have to add an auxilliary battery pack to power the 50,000 watt faux straight pipes simulator.
11-14-2013, 12:50 AM
#16 (permalink)
5 Gears of Fury
Am I the only one hoping they make it a diesel hybrid? Like a Volt sort of idea. Then at least you could get the diesel noise to go along with your dually truck ha ha
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
11-14-2013, 01:09 AM
#17 (permalink)
NightKnight
The drivetrain of the sub allowed for a lot more slip than the drivetrain of the truck would... plus I believe the operating parameters (ambient temps, grades, loads, etc) of the truck will be significantly broader than the sub's... so that is probably not a valid comparison.
I agree it's not impossible, but if the truck is going to be rated comparable to an F-series truck (which can tow its own weight and then some), then it seems like battery management will be a bit more complicated than on a passenger car.
11-14-2013, 08:41 PM
#19 (permalink)
I'd like to see a Tesla truck in the Camping World Truck Racing series (part of Nascar). During pit stops, the Tesla would swap battery packs, rather than refuel with gasoline. Nascar would need to come up with the equivalent of a restrictor plate for Daytona and Talladega. Maybe some extra resistors strapped to the motor controller.
Bicycle, 125cc motor scooter, 4.0L pick up truck
11-15-2013, 03:37 AM
#20 (permalink)
I always wondered why Americans need these pick-up trucks with long snouts.
If I was a construction worker or a marine vessel hauler I would get a more practical Iveco Daily (available with dual cab, tiltable cargo bed, crane and what not) which use space more efficiently and have a higher payload and are more fuel efficient.
