Old 06-02-2019, 03:06 PM   #391 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
IF you really need POWER Generator
I suggest Thermoelectric generator..
it turns IR(heat) into power...
Think outside the box
a 45Watt version will be almost $800... you could hook it upto the output of the exhaust...300C will give you about 45watts of power
Old 06-02-2019, 04:22 PM   #392 (permalink)
90 day: 56.29 mpg (US)
That has also been discussed before. The problem with thermodynamic generators is the cooling side. You simply need an enormous cooling fin.
On top of that TEGs are very expensive for the power they produce, so only make sense in applications that run continuously. Most cars are used less than 10% of the time.
Xist (06-02-2019)
Old 06-02-2019, 04:24 PM   #393 (permalink)
People always say peltiers are too fragile.
Since the early-2000s, nearly every major automaker and exhaust supplier has experimented or studied thermoelectric generators, and companies including General Motors, BMW, Daimler, Ford, Renault, Honda, Toyota, Hyundai, Valeo, Boysen, Faurecia, Tenneco, Denso, Gentherm Inc., Alphabet Energy, and numerous others have built and tested prototypes.
https://en.wikipedia.org/wiki/Automo...tor#Challenges
Mentioned here in 2012: https://www.caranddriver.com/feature...ogies-feature/
They started a seven-year program with Ford and BMW: https://www.greencarcongress.com/201...-20120928.html
RedDevil (06-03-2019)
Old 06-03-2019, 07:44 PM   #394 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.06 mpg (US)
Originally Posted by oldtamiyaphile View Post
Most new cars do this factory. On a full charge, my Renault will go about 6 miles before engaging the alternator, other than under deceleration.
My 2017 Civic does it too, nice feature to have.
Old 01-02-2020, 07:08 PM   #395 (permalink)
Hand/peddle crank generator :P
make your passenger do it LOL
Old 01-05-2020, 04:36 PM   #396 (permalink)
Old 01-05-2020, 04:58 PM   #397 (permalink)
this
Best Hand-Crank Generators: 5 Portable Hand-Crank Power Generators
Or solar panel and big capacitor bank??
Also another option is use alternator that that has alternator field disconnect.
Old 01-05-2020, 11:02 PM   #398 (permalink)
I prefer lassoing a semi, but when someone cuts you off you are going to have a bad day.
Old 01-06-2020, 12:15 AM   #399 (permalink)
i'm in a big SUV,
I read that sport-utility vehicles are more likely to be in fatal accidents.
Fatal to the people in the other car.
https://youtu.be/Mf6gYRYB2fc?t=200
100% true I saw a 1996 tahoe right into a 1990s Honda wagon accord it ripped the accord apart( the driver side door was compressed to the passenger side) and the passengers got ejected.. mind you the Tahoe was going 55mph (speed limit) and the accord made an unsafe u turn in front of the accord.. the guy in the tahoe walked away..
same
it also happened again last year as well another car made an unsafe turn they got double t-boned on both side of the car (a truck and car hit it in both directions at the same time)
lets just say the car went from 6 feet wide to 2 feet wide
Old 01-06-2020, 12:20 AM   #400 (permalink)
Everyone knows that real men drive Mirages!
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-09-2010 11:41 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
