Old 11-25-2009, 06:34 PM   #51 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by Bearleener View Post
Assuming an alternator efficiency of 55%, an engine efficiency of 29%, the electric power consumption is 1.96 kW * 0.55 * 0.29 = 313 W.
Sounds reasonable (somewhere here I'd seen that keeping the engine
Bearleener: I did a more accurate audit of the electrical demands of my car, and it's much lower than I originall guesstimated (based on someone else's Honda Civic figures).
FYI the results are here: http://ecomodder.com/forum/showthrea...olts-8908.html
MPGeo (09-17-2016)
Old 11-25-2009, 07:05 PM   #52 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
very cool post thank you so much! I knew it did not take much power to run these things. when my alt died first day I got my metro it died so STRANGELY I did not immediately suspect alternator until I saw the lights DIMMING but the engine still ran eventually the enginer started having trouble but as soon as I turned off the headlights it was fine again (thats how I knew it was a power issue)
60watts. Amazing :-)
Old 11-26-2009, 09:20 AM   #53 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 VW Golf wagon
90 day: 40.36 mpg (US)
@MetroMPG: Thanks for those data, that's all amazingly low, especially the 60 W to run the engine!
@Nerys: yeah, the 29% refers to the heat of combustion.
You ever notice that birds pulse & glide, too?
Old 11-26-2009, 03:06 PM   #54 (permalink)
JackMcCornack's Avatar
Thanks MetroMPG, I think I'll go to an auto electrical shop and see if I can set it up with two regulators--one that's the default regulator and is set to charge to slightly less than full charge, and one that switches on with braking and is set to charge full charge. And bartender, I'll have one of what the man in blue is drinking! :-)
[EDIT--Oops, I was still on Page 5. Nerys, my whimseyed response was to...
>I had assumed when people say that they mean 29% of the atomic energy in
>the structure of gasoline IE half of what comes out of a matter antimatter reaction
...which seemed an unusual enough assumption to be worth a smiley.
But with the info on Page 6, and the fact that my Kubota only needs as much power to run as does a flashlight (it has a fuel valve solenoid to kill the engine if the electrical system fails), if I use LED turn signals and run with my headlights off, maybe all I need is a solar panel.]
Modding MAX, a Kubota-powered classic sports car
http://www.kineticvehicles.com
Last edited by JackMcCornack; 11-26-2009 at 03:30 PM.. Reason: Hadn't refreshed this thread since lunchtime yesterday
Old 11-26-2009, 04:36 PM   #55 (permalink)
Grrr :-)
Nerys's Avatar
well whenever I hear "total energy of" this to me means 100% conversion of the matter to energy. the only know way to do this is a matter/antimatter reaction (even nuclear only converts a tiny fraction of total energy of matter to energy.)
so I heat people say 20% 30% and I am thinking your nuts. if you got 29% the energy out of gasoline you could circle the globe on a gallon of gas or something nutty like that :-) I mean a few micro grams of antimatter could take us pretty much anywhere in the solar system. a Gram anywhere in our part of the galaxy :-)
then while reading your post it dawned on me that it was NOT 29% of the available energy of gasoline but 29% of the HEAT you get when you combust it which makes a lot more sense but is very deceptive. Cars are actually less than 2% efficient
when people understand THIS it starts to get easier to describe why EV's are sooo damned good :-)
I think there is enough roof area and back window area for 100watts of solar panels. (which should net you 60watts in less than ideal conditions)
in theory combine this with 2 deep cycles and your "parked" time in the sun should be enough charge time to make up for other usage such as driving at nights with the lights on Especially if you convert as much as you can to LED's
ie you might be able to stay "unplugged" except once in a while if you do a ton of night driving and it rains for a few days then you might have to plug in a trickle charger to "top off" the batteries.
Put it this way its close enough that my curiosity is peaked :-) I am even looking into LED headlamps. but man are they expensive $120 a pop and I would need at minimum 2 and very likely 4. (800 lumens a pop 10watts consumed) so if I needed 4 my power load would drop from 100 watts to 40watts if I could get away with TWO (say in well lit cities etc..) 100 watts to 20 watts would make a huge difference :-)
no need to mount panels and stuff I would use the Flexible panels and attach them directly to the roof like a SKIN. Maybe even the hood too (but then you start to screw with aesthetics) if you did not care about aesthetics you could probably get 200watts of panels on the car and NOT screw your aero. Then toss another panel in the hatch area (someone already did this and it fits perfectly)
now you should have MORE than enough power to get rid of the alternator if you get the LED conversion done and are careful with power usages.
heck maybe even get a few peltiers in on the action if we can make them produce some usable watts. they would be especially useful in the WINTER where you have nice cold air for the differential requirements AND at the same time winter is when solar will be lacking (less sunlight and more angle)
Old 11-26-2009, 05:08 PM   #56 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Aren't the flexible panels much less efficient though, making them less than ideal for the limited-space adventures of car solar?
Old 11-26-2009, 05:13 PM   #57 (permalink)
Grrr :-)
Nerys's Avatar
I would think with that much surface area they would be "good enough" especially if you used hood space. remember anything over 100watts and your golden.
Old 02-28-2010, 02:19 PM   #58 (permalink)
BigWhiteWhale - '01 Ford F250 Lariat Crew Cab Superduty
The newer diesels need power for engine management, throttle control etc.
Old 02-28-2010, 04:32 PM   #59 (permalink)
...beats walking...
...sorta begs-the-question, *why* can't cars have AMP gauges as they did in the 'olden' days (as well as VOLT gauges)?
Old 03-01-2010, 01:45 AM   #60 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
LOL, You wouldn't want anything distracting people from texting while they drive!
Also, people would get a clue about how much juice all their accessories are sucking. You really don't want people to have a clue do you?
I put an analog one in my alternator-less Previa. Heater fans and window wire defrosters are your enemy!
Speaking of data, a good PC based scanner can graph you all kinds of data. It's all there. One day perhaps they will let us access it with a stock readout like some clever prius folks have done with CAN-View.
I'm getting ready to run the 12V side of my Prius on deep cycles once I get hold of a good DC-DC converter. This time I'm actually going to test it.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-10-2010 12:41 AM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 07:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 01:25 PM
