Old 07-10-2012, 02:37 PM   #1 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
Test: Windows open vs. closed
Yesterday i did a coastdown test with my 4dr Civic. I did 2 tests in each direction with all windows closed and the same test with front windows open thinking this would be worse on fuel economy because it acts as a parachute.
I used my android phone with Torque app to log the coastdown times so they are the most accurate you can get.
The result, exact same coastdown time with windows open or closed.
The Following User Says Thank You to GRU For This Useful Post:
3n3rgystar (07-10-2012)
Old 07-10-2012, 03:09 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
What distance was the run? What was the ambient temp? Any wind? Did you try using a tuff test at the windows to see if the air flow was being sucked in/out of the car?
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 07-10-2012, 03:28 PM   #3 (permalink)
GRU
GRU's Avatar
Temp was about 75 with very little wind. I did not do tuft testing because i was just trying to see how much do open windows affect fuel economy.
The test was caosting from 70km/h (about 45mph) so maybe i would see a difference around 60mph
Also, i know i should do a average MPG test with windows open/closed but the cruise control isn't working right now
Old 07-10-2012, 03:33 PM   #4 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
45? Do at least 60, if not 70. The faster you go, the more aeromods show. And did you coast to a stop, or just down to 20mph or so?
Old 07-10-2012, 04:14 PM   #5 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I wasn't very scientific about it, but I tested this recently. There's a hill I can coast down, starting at 50 MPH and ending at a stop sign. I usually end up going around 22-23 MPH where the road levels off before I need to brake. Windows are usually closed or slightly open. I tried it with all 4 windows open in the Wagon. My speed dropped down to 20 MPH. All done on different days, but the windows closed speed of 22-23 MPH has been pretty consistent.
My friend's heavier and more aero 2002 Jetta only drops to 35 MPG on the same road.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 07-10-2012, 04:17 PM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I ran my 4 door jag (99 Vaden Plas) with windows open and windows closed several yrs ago on a stretch of highway at 65mph (on cruise)10 miles up and 10 miles back , 4 trips. using the scangauge the window down cost me 3mpg on a car that did 26mpg on the road.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-10-2012, 04:31 PM   #7 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
IMO, there's too much variability in the methods you folks have discussed. The way to do it correctly is the way Darin tested inflation pressure.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 07-10-2012, 10:33 PM   #8 (permalink)
90 day: 51.82 mpg (US)
FYI:
http://ecomodder.com/forum/showthrea...open-8863.html
