Old 12-21-2020, 03:08 PM   #1 (permalink)
External air curtains
Throttle stop drag tested, tuft tested and pressure tested. The most effective 'simple' modification for measured drag reduction that I have done.
JacobLeSann (09-29-2023)
Old 12-21-2020, 03:47 PM   #2 (permalink)
The best candidate I've seen, from Ecomodding Central. I suggested he search on 'edgarwit':
https://ecomodder.com/forum/showthre...eas-38904.html
"We're deeply sorry." -- Pfizer
Old 12-21-2020, 06:04 PM   #3 (permalink)
Awesome.
I appreciate you trying new things and testing them rather than dismissing them as something only large corporations with vast resources and staff of professionals can do.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
JulianEdgar (12-21-2020)
Old 12-22-2020, 04:54 AM   #4 (permalink)
IRONICK's Avatar
And why does it look so ugly? The modifications must be applied in such a way as to be related to the current design of the car. It's like they're taken from the truck ...
I would have chosen the solution inspired by Mercedes-Benz A-Class/C-Class.
Old 12-22-2020, 05:12 AM   #5 (permalink)
Well when you do so, you can show us the results.
Old 12-22-2020, 12:05 PM   #6 (permalink)
And why does it look so ugly? ... It's like they're taken from the truck ...
That's a section of aluminum extrusion. I consider it proof of concept.
Old 12-22-2020, 04:09 PM   #7 (permalink)
IRONICK's Avatar
It is totally useless in this case. An aluminum (or any other material) sheet does the same thing.
Old 12-22-2020, 04:16 PM   #8 (permalink)
You'll have to show us the results of your testing - this is an interesting area.
Vman455 told me he used sheet metal for external front air curtains and recorded a drag increase on his Prius - but they gave much better stability when passing trucks.
As I say, I'd love to see the results of your tests.
Old 12-22-2020, 04:39 PM   #9 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Yes, this is correct--the sheet metal front ducts by themselves appear to increase drag based on fuel economy testing. But when I compared pressure difference on each side of the car just behind the front wheel arches (at Julian's suggestion--thanks!), I found that the average pressure difference between sides in a 25 mph crosswind was nearly 15% lower with the ducts on. The wing sections seem to be a better solution, and something I'll probably try in the future.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
JulianEdgar (12-22-2020)
Old 12-22-2020, 05:08 PM   #10 (permalink)
Can you post a comparison of the two approaches?
I speculate that a flat plate would have critical angle-of-attack and positioning criteria. I further speculate that a curved plate would approach the result of the airfoil section.
I've been thinking about air curtains on a Geo Metro. It looks like I could add a partial diverter on each side (flushed out to the upper bumper) with curved plates capping the void created.
