Old 07-26-2021, 09:06 PM   #81 (permalink)
It drives me nuts when people say 'angle' when they mean 'tangent' but I don't burn what little social capital I have trying to get people to change.
I meant what I said - angle. No curvature needed for a hatch extension, especially in initial tests.
Old 07-27-2021, 12:44 AM   #82 (permalink)
No curvature is needed for a tangent!
It's a trigonometric function based on the triangle. Think of it as the antinormal.
You can't be wise and in love at the same time. -- Bob Dylan
Old 07-27-2021, 12:55 AM   #83 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Just as long as no one goes off on a tangent.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
freebeard (07-27-2021)
Old 07-27-2021, 02:21 AM   #84 (permalink)
ecomodder.com: What sort of shape are we in?
Old 07-27-2021, 02:26 AM   #85 (permalink)
As a writer, I use definitions that agree with the dictionary.
tangent
/ˈtan(d)ʒ(ə)nt/
noun
a straight line or plane that touches a curve or curved surface at a point, but if extended does not cross it at that point.
- Oxford
We've already seen other people here changing the definitions of words when it didn't suit them, but I didn't expect you to start doing so.
Old 07-27-2021, 02:50 AM   #86 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
Around here it's normal to go on a tangent.
The Following User Says Thank You to jakobnev For This Useful Post:
Vwbeamer (07-27-2021)
Old 07-27-2021, 05:37 AM   #87 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by JulianEdgar View Post
No flat roads and no straight roads = near impossible to test. I currently drive 30 miles to my test location.
I also don`t like if something are said what is known to be false like the comment above. I havent seen Julian go fix his claims/comments in topics which have been proven wrong. Or say I was wrong.
When you read topics here you need to do your own research and see what is true or not. Is there any physical reason to valid or not. I trust physic laws more than anything else.
For the onroad testing:
I only quick test my changes on curvy road which had uphills and downhills sections. Results are even so accurate as Mr Edgar thinks is impossible on the road.
Works well for diesel and electric cars. Petrol ones I havent tested but don`t see any reason why it would not work also for petrol.
On that video Julian calculated accuracy of 0,6% to other direction and 0,7 percent to other.
Julian says only 1% accuracy is possible on onroad testing, because I believe thats the limit he has said in his books or that is what it possible for him. Opinion in the matter is not possible to get turned otherwise.
I on the other hand thin even more accuracy is possible when you think the testing even more what you want to achieve and how will you achieve them. That depends on what you testing, aero or engine mods etc...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Piotrsko (07-27-2021)
Old 07-27-2021, 10:18 AM   #88 (permalink)
Im gonna say that the available test measurement total accuracy is the only thing that affects the test. If it's a nonstandard test parameter, then you need to sample more and different to get the boundaries of that sample, so going up and down, left or right gives you meaningful data, but only if you measure all the data available. Besides, nobody takes only one data point for a test, you use the mean. If I use only one data point, my F250 gets 99mpg. (Down a steep hill towing a 7,000lb trailer with a tailwind, instantaneous)
Old 07-27-2021, 12:19 PM   #89 (permalink)
tangent
/ˈtan(d)ʒ(ə)nt/
noun
- Oxford
I blame Euclid.
I can cherry-pick definitions too, Oxford is correct only for a subset of 'curved'. Arcs rather than Bezier curves. How is your tangent measured? Rise over run? That's a tangent not an angle.
...that's not normal.
Old 07-27-2021, 04:32 PM   #90 (permalink)
I blame Euclid.
So another person here who doesn't accept what the standard dictionary says, but instead has their own definitions of words.
Why am I not surprised - all the better to add to the confusion.
Let's absolutely try to make car aerodynamic modification as difficult as possible, shall we? Hmm, how can we do that? I know! Let's use erroneous concepts, give words meanings that don't match standard dictionary definitions, and put in irrelevant links. That'll do it!
What a great game this is! Hours of fun! Let's see if I can do it.
Did you know that attached flow isn't really attached flow if the angle descends more quickly than the template?
Onomatopoeia boundary layer.
Irrelevant link.
Hey, I think I am getting the hang of it now!
