Old 12-15-2009, 11:07 AM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
tire size (Does ScanGauge have adjustment for different sizes)
Santa is stopping at my place first this year.....as I sit on my porch wanting for my scangaugeII............
I run 255x45x18 tires. the factory size is 245x45x18. I know that the car odometer and mpg gauge is off by about 3% because on my last long roadtrip i used my garmin nuvi gps to track my true mileage.
Does the SGII allow for adjustment for tire size?
Old 12-15-2009, 11:10 AM   #2 (permalink)
90 day: 51.82 mpg (US)
Yup. There's a "speed" offset which you can use to correct for gearing/tire changes or OEM errors in the speedometer/odometer.
FYI, you can view the ScanGauge user manual online:
http://scangauge.com/support/pdfs/SGMan5_1.pdf
(SG2 with Xgauge link)
mcrews (12-15-2009)
Old 12-15-2009, 11:29 AM   #3 (permalink)
mcrews's Avatar
thanks Metro!
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire size vs. hub width and weight limits Piwoslaw EcoModding Central 3 06-25-2009 06:50 AM
change in tire size mully General Efficiency Discussion 8 09-28-2008 08:13 AM
