Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-08-2011, 12:50 PM   #11 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Every mid 90's Ford Exploder came with these tires from the factory, tireblast indeed.
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
Joenavy85 (07-09-2011), mcrews (07-08-2011)
Old 07-08-2011, 12:56 PM   #12 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
now that is what I call subtle humor!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-08-2011, 01:10 PM   #13 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by mcrews View Post
On my last set of tires, I had Radial Tire Store of Sacramento, put nitro in the tires. we had discussed it half way thru my last set and he said that it really needs to be done when the new tire is installed.
I run 44psi w nitro and the psi fluctuates 1psi (the Q45 has psi senors. In the past it was as much as 4psi different hot and cold.
The trip that is documented in my signature (third link) was my first ever over 30mpg.
I reallt thing the nitro played a role in that.
There must be another explanation. Does anyone really think more pure N2 is exempt from Boyle's law?
I'm not coasting, I'm shifting slowly.
Old 07-08-2011, 02:21 PM   #14 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by UFO View Post
......Does anyone really think more pure N2 is exempt from Boyle's law?
Boyle? Wasn't he that guy who played Frakensteen? I didn't vote for him, so why is he making laws?
Old 07-08-2011, 02:41 PM   #15 (permalink)
UFO
UFO's Avatar
LOL.
Boyle's law (sometimes referred to as the Boyle-Mariotte law) is one of many gas laws and a special case of the ideal gas law. Boyle's law describes the inversely proportional relationship between the absolute pressure and volume of a gas, if the temperature is kept constant within a closed system.[1][2] The law was named after chemist and physicist Robert Boyle, who published the original law in 1662.[3] The law itself can be stated as follows:
For a fixed amount of an ideal gas kept at a fixed temperature, P [pressure] and V [volume] are inversely proportional (while one doubles, the other halves).
I guess in this case, the temperature varies with a more-or-less fixed volume, so the pressure is proportional to temperature.
Old 07-08-2011, 06:00 PM   #16 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
P*V=n*R*T
P: Pressure
V: Volume
n: the ammount of molecules of gas
R: 8.3144621 (gas constant which is the same for all gasses)
T: Temperature
The above equation says that no matter the gas for a given change in temperature their will be the same change in pressure given a fixed volume.
He was making laws before you were born.
Old 07-08-2011, 06:05 PM   #17 (permalink)
TheEnemy's Avatar
Tell you what I'll sell you a filter that will filter the nitrogen, for $200.
It will pay for itself in less than 10 fillings.
disclaimer: depending on atomspheric conditions the concentration will vary
Old 07-08-2011, 06:32 PM   #18 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I have been giving this some thought, and while I agree that it shouldn't really matter what gases are used (air vs N2) to inflate tires, I do think that not enough attention is paid to water.
That's right - water. If humid air is used to inflate tires, then it is possible for the evaporated water to condense out as the tire cools (especially if the tire is initially inflated during periods of warm weather, and then that same tire is used throughout winter). Such condensation will significantly affect tire pressures. That would explain why mcrews saw his tire pressures vary as significantly as they did before he used N2.
Old 07-08-2011, 09:32 PM   #19 (permalink)
rmay635703's Avatar
I say fill your tires up with pure carbon monoxide, it would virtually eliminate oxidation issues.
Old 07-08-2011, 10:22 PM   #20 (permalink)
MPGuino Supporter
t vago's Avatar
