Old 11-19-2012, 08:36 PM   #1 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
which tires?
I have a set of winter tires for my car but they are kind of worn down now and are around 4/32. My all season tires are almost brand new and are marked m&s so i'm thinking about just using them for the winter..
We sometimes get a lot of snow here so i'm thinking i'm better off running the all season tires that have great tread than winter tires that are almost bald?
Old 11-19-2012, 08:55 PM   #2 (permalink)
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Get new winter tires, your 3 seasons are nothing but a compromise.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
Old 11-19-2012, 09:21 PM   #3 (permalink)
M&S rating comes only because it's 50% rubber vs void space, nothing about winter or mud traction. Learned that just a few weeks ago and happy to pass it along.
Also recently watched a tire test video where they did wet braking test, 4/32 is unacceptable for anyone in my family but me. It was done by tirerack.com
Get some new winters, burn up your old winters come spring (if willing and able to keep good braking distance) or toss them now. I'd burn them up on the rear 2 at a time realizing when wet than I need extra distance to be safe.
Old 11-20-2012, 11:59 AM   #4 (permalink)
GRU
GRU's Avatar
I wish i had the money to buy new tires...i know its not a good idea to mix winter and all season tires but i might just use the 2 good winter tires on the front and the good all season tires on the rear...
The picture below is showing the all season tire on the left and the worn winter tire on the right
Old 11-20-2012, 11:41 PM   #5 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
You don't have a set of tire chains, do you? I still have mine from being assigned to northern Utah. Carried them around all winter up there, just in case. My truck did okay with all seasons, but I also put 300# sand in the bed.
Old 11-20-2012, 11:46 PM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Maybe its just the picture, but it looks like there's enough tread on those snow tires for another season.
Old 11-21-2012, 12:30 AM   #7 (permalink)
6.4 - '19 Ram 3500
Those winters, as worn down as they are, will do a much much better job on ice then your all seasons.
Old 11-21-2012, 11:55 AM   #8 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
+1...I'd run them one last winter & use them up completely in the spring.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 11-21-2012, 08:48 PM   #9 (permalink)
GRU
GRU's Avatar
i measured the center and it's about 4mm. about 1/4 from the middle (or from the side's) i'm showing about 5.5 mm so they should be good...and those are the rear's, the fronts are at 5.5mm in the center and 7 to the sides.
Thanks for the tips
Old 01-07-2014, 11:31 AM   #10 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Hi
star deciver
like your quote at bottom of your postings. very relavent to where i live.
Lol :-) :-) :-)
The Following User Says Thank You to chefdave For This Useful Post:
star_deceiver (01-11-2014)
