Old 09-12-2009, 11:44 AM   #41 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Probably completely impractical, but I do wonder if welding up custom axle halves (quarters?) and adapters and mounts so you can use a completely different gearbox (like out of a motorcycle or??) wouldn't be less expensive and more in reach of the diy. Does 1 wheel drive help efficiency by any chance?
Old 09-12-2009, 06:37 PM   #42 (permalink)
dcb
needs more cowbell
dcb's Avatar
or, pull the axle out of one wheel hub and lock it down so it can't turn, and the other wheel then turns twice as fast, aka quick and dirty super overdrive with one wheel drive. You did say you have a spare tranny?
Old 09-12-2009, 10:04 PM   #43 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
You wanna explain how that would work?
Old 09-12-2009, 10:33 PM   #44 (permalink)
dcb
needs more cowbell
dcb's Avatar
same thing that happens when one wheel spins on the ice. If you removed an axle shaft from the car and replaced it with something to keep the associated transmission output shaft from turning, then the other output shaft would turn twice as fast (i.e. super overdrive ) and really give the cogs a workout too.
Old 09-12-2009, 10:38 PM   #45 (permalink)
But... it won't turn twice as fast.
If the final gear ratio is 2:1, it's 2:1 with both wheels turning, and it's still 2:1 even if only one wheel is turning.
Don't believe me, jack up the car, put it on stands, put it in 5th gear, and let it idle (it will stall instantly if it falls).
Once both tires get moving at the same speed, stop one. The other one won't be spinning any faster, because the engine's speed hasn't changed, and neither has the differential speed.
All that starts spinning faster are the spider gears in the differential, and you start wearing the pin that holds them together. Eventually, it will fail, shooting into the side of the diff case and grinding itself to oblivion... at least, that's what happens when you make 1-tire-fire in a Chrysler.
Old 09-12-2009, 10:43 PM   #46 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
I think with a differential it would spin 2x faster, I have no idea what a FWD car has, so I can't answer the question.
Old 09-12-2009, 10:47 PM   #47 (permalink)
Jack up your truck and try it. The differential is geared the same no matter how many tires are spinning, no matter if it's FWD, RWD, locker, LSD, etc.
The only time you'll get 2x speed out of a tire in this case is when one was spinning backwards, as is the case with open differentials. If they're both spinning forward, or one is spinning and one isn't, the speed doesn't change.
Old 09-12-2009, 10:55 PM   #48 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sorry Christ, but that just doesn't sound right. The only time the other wheel affects the rotational speed of the first is when it is spinning backwards you are saying?
Edit: no argument that there are plenty of examples of self destructing differentials though. This is not an entirely serious suggestion
Old 09-12-2009, 11:20 PM   #49 (permalink)
Precisely. The differential's speed is based on it's input, not the wheel speed. The wheels' speeds are independent of each other.
This means that if the engine is coupled directly to the differential, and the differential's ratio is 2:1, when the engine speed is 2000 RPM, the output speed of the differential is 4000 RPM, regardless of which wheel it goes to. Neither wheel will spin any faster than 4000 RPM, regardless of the opposing wheel's speed.
If you are NOT driving the differential, you can spin one wheel either forward or backward, and the other wheel will spin 1:1 with it in the opposite direction, unless you have LSD engaged, or you have POSI or a welded diff.
Old 09-12-2009, 11:26 PM   #50 (permalink)
If you hold one side fixed, and continue to apply torque, the other side of the differential rotates at twice the speed it normally would (twice the speed of the ring gear and housing).
source:
Differentials (Open, LSD and so on)
I have a Lego Differential, but I can't find it I would demo it if I could.
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 12:32 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Home made hybrid (using access to 5th gear on FWD transaxle) AXMonster Hybrids 17 10-19-2008 05:35 AM
