Old 01-03-2011, 03:53 AM   #11 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Originally Posted by alohaspirit View Post
How are those miata rims treating you?
You have a very good eye !
They were great, while they were on the ECHO. Haven't done any serious monitoring, but the FE slightly increased after putting them on.They're quite light compared to my currently installed steel rims (Winter season).
I actually restored them. Bought the set for $50. Here's a link if you want to see before/after pictures.
Wheel spacers -- need advice - Page 2 - Echo Exterior/Interior - yarisfans - Toyota YarisFans: The Echo and Yaris Fans Community
Cheers !
Old 01-03-2011, 12:52 PM   #12 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Originally Posted by Piwoslaw View Post
I didn't know that you could order custom signed coroplast from EcoModder
will my under-engine coroplast be ok next to the oil pan?
Past Present Future?
Old 01-03-2011, 11:43 PM   #13 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Yes it should be fine. Mine is right up on it and has had zero issues.
Old 01-07-2011, 01:26 AM   #14 (permalink)
Grasshopper
thanks
Old 01-27-2011, 12:03 AM   #15 (permalink)
Grasshopper
quick update
i started the echo up today
idled her for over 10 minutes while i cleaned it up some
then took a short drive up, down and around the hill
my temp kicked up to 205F
(it did go down when coasting downhill though)
hopefully that temp will drop if i just get in and drive normally
Old 01-27-2011, 07:58 AM   #16 (permalink)
105F is cold -- 105C is hot.
Old 03-03-2011, 06:44 PM   #17 (permalink)
Grasshopper
i might have to take off my lower block (or cut holes)
i have a 4 mile one-way commute and if the weather is warm or theres traffic
temp goes over 200F
(the highest it hit was 215F going up my hill for 10 sec)
temp is fine if weather is cool and i catch all the lights
im interested if anyone has any input
Old 03-03-2011, 09:33 PM   #18 (permalink)
CigaR007's Avatar
Have you blocked the upper grille too ?
From what I witnessed on the Echo, most of the cooling is done via the lower grille. Since you live in a warm and mountainous region, it is not the ideal thing. As you said, creating an opening on the lower grille block will allow for better cooling.
I had the same problem when I completely blocked the lower grille earlier this Winter. Had to clear at least one of the 3 holes on the lower grille to maintain a constant 186-190F.
You might have to clear a larger area for proper cooling. I believe the upper grille block would be a better alternative in your case.
Old 03-03-2011, 10:42 PM   #19 (permalink)
Grasshopper
yeah, i was probably going to cut a few holes
then if that doesnt work, id remove and block the top like you did
Old 03-08-2011, 04:40 PM   #20 (permalink)
Grasshopper
Update:
took a longer drive than usual and hit 200F going TO my destination
removed the block, returned home and still hit 195F going up my hill!
Guess that means if you live in Hawaii, dont put a lower grill block on your Echo.
(its just too warm here)
Next:
Upper grill block
