Go Back   EcoModder Forum > Classifieds > For Sale
Old 02-05-2009, 12:36 PM   #1 (permalink)
the firefly - '91 Pontiac Firefly Base
Last 3: 50.5 mpg (US)
White Lighting - '94 Honda Civic HB VX
90 day: 48.65 mpg (US)
SilverBullet - '99 Honda Civic EX
For Trade: 1994 Honda Civic VX in North GTA
I would like to trade my 1994 Honda Civic VX for;
Acura Integra 90-01
Honda Civic 88-95 - NO CX's unless it has something other than original engine.
Krown Oil Sprayed in Fall
New Passenger side front fender
New Catalytic Converter
The rear wheel wells are rough and will require work to safety.
Quarter sized hole in driver side door where door trim would normally be
Rust under gas door
NO HOLES IN FLOOR
330000km on odometer engine runs great, will do compression test if required
AC works used it this past summer.
Has 2 sets of wheels, VX wheels with 2 new Canadian Tire MM SE tires 175/70r13 and Honda Steels with trim rings and snows 50% 175/70r13
White Exterior, Navy interior with black cloth armrest console, honda carpet mats in rear.
New O.E. PPG Windshield with Blue Tint at top, new wipers one piece new style blade
New 02 sensor in fall, NGK spark plugs (proper heat range #4s), Premium Plug Wires, New Distributor, Air Filter, Fuel Filter, Changed Transmisson Fluid, New Thermostat, New Radiator
Great Daily Driver , reliable and a fuel sipper if you drive her right.
Best tank was 600km to 30L.
d_gagnier at rogers.com
Located north of oshawa and whitby
Last edited by flydude1221; 02-05-2009 at 12:39 PM.. Reason: Just checked ODO only has 330000 and change.
Old 02-05-2009, 03:59 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Where were you 3 years ago when I started shopping for VX's and Metros in Ontario?
Good luck on the sale/trade.
FS: Honda Civic VX Rims and Tires ECOMODDER BENEFIT AUCTION XFi For Sale 26 02-22-2014 11:30 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
FS: 1992 Honda Civic VX 98K $1200 in RI. Not mine! XyKo For Sale 0 08-19-2008 09:23 PM
fs: san diego honda del sol d15z1 VX Civic 50+mpg CALIFORNIA BAR Certified conversion fistopher For Sale 26 08-01-2008 07:43 PM
