Old 04-06-2008, 11:48 PM   #31 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by trebuchet03 View Post
Arg... I really hate statements like this...
Tires make biggest difference in MPG below 50 mph; aerodynamics is the most important factor over 50 mph.
Yeah, that sounds to be an oversimplified statement -- probably to appeal to city-only drivers to focus mostly on tires, etc. The graph doesn't seem to equate. I used the x=0 as well (which is confirmed by the legend). Probably what their doing is stating that aero and tires are equal at 50, but is actually double, which negates the x=0 assumption of evenness -- which happens at, what ~18 mph?
Originally Posted by Big Dave
Even the UP's Sherman Hill grade and CSX' Cheviot Hill got bypassed.
The UP/BNSF Cajon Pass (~11%) and Tehachapi Loop series at 2.2% is also a tricky combination. But -- it's the main passage from LA to points East (big Intermodal traffic) so they keep rolling. Risky business.
The train at the top of the hill is released and goes into dynamic braking and feeding the electricity back into the catenary, where the climbing train can use it. Very efficient.
That sounds like a great idea -- aside from the cost, the fuel saved on the ascent would pay for itself quickly.
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-06-2008, 11:51 PM   #32 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I figured it out... Zero is at the line of the item below the one you're looking at. The zero for tires occurs at the top of "other" and the zero for aero occurs at the line for tires. When you calculate the range based on that - it matches the data written (and a graph a few pages down)...
A poor method to communicate data
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-07-2008, 12:36 AM   #33 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
And that said - according to that chart - aero beats tires around 20mph.. what gives? I may be reading that chart wrong (whenever I use a chart like that - the x axis is zero for everything)...
The one right over the 50mph quote, right? It seems about right according to the graph. At 50mph aero power is about the same (It looks it be slightly less, but not by much) as rolling power, and after that aero becomes a larger component by a wide margin.
Edit-OIC! Yeah, that's a funny way to graph it but it allows people who don't have experience with graphs to see the breakdown and differences.
That being said, since IME, a lot of transport companies, such as LTLs, tend to run their trucks at less than 80,000lbs GCW, the point where aero drag is the same as rolling is probably ~30-40mph.
Old 04-09-2008, 06:01 AM   #34 (permalink)
roflwaffle's Avatar
Oh, and the reason why I'm seeing grocery trucks doing 50-55mph consistently is because their GCW is probably less than half of the 80,000lb GCW Cummins assumed, so at 65mph the ratio of aerodynamic to rolling drag is probably about three or four to one as opposed one and a half to one, meaning that as long as they use their gearing well, dropping 15mph probably increases fuel efficiency by ~30-45%. As diesel prices increase/hold, even hedging will become harder, so I imagine carriers will start driving efficiently in greater numbers.
Old 04-30-2008, 11:17 PM   #35 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Look what I found: http://www.alternative-energy-news.i...hybrid-helper/
Old 05-01-2008, 02:53 PM   #36 (permalink)
Maybe they should build them like this.
Yes, it was a 727, now it's a limousine with seating for 50, top speed of 124mph (200kph) and runs on a 6 cylinder turbo-charged diesel.
Old 05-01-2008, 03:38 PM   #37 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
picture no worky
Old 05-01-2008, 09:15 PM   #38 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
After all this reading I thought about this ... The gap between truck cab and trailer is quite large and no doubt impacts efficiency. What if at highway speeds the fifth wheel was able to draw the trailer closer to the cab thus eliminating or reducing the gap and improving MPG's. I guess a technology very similar to the porsche tails or the VW turbo wing, just on a larger scale.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-01-2008, 09:59 PM   #39 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Here's an interesting SAE paper on aeromodding big rigs: http://www.solusinc.com/pdf/2003-01-3377.pdf
And here's their website with links to their products in the lefthand column: http://www.solusinc.com/index.html
Old 05-01-2008, 10:14 PM   #40 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I think Cajon Pass grade is 1.1%. The theoretical max grade for steel wheels on sanded steel rail is about 6% for the locomotive only.
As a rule one uses a cog railway in excess of 5%.
Back on topic, it would astound you how far trains can coast. Quite often you pass the "ruling grade" and coast 50-70 miles or more to the division point. For instance on the old B&O (now CSX) St. Louis division the ruling grade westbound was at Loogootee Indiana. Once over this grade, the train coasted all the way to Cone Yard in East St. Louis. Yep. The train coasted all the way across Illinois and was on the brakes just outside Cone.
Trains are 4-8 times as fuel efficient as rubber-tired vehicles, but they are terrible for door-to-door service.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Truckers slowing down to save fuel Cd General Efficiency Discussion 23 08-25-2008 08:19 PM
