Old 04-28-2009, 12:51 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Did you have your side window(s) open? That would account for some of the tubulence seen at the glass edges. I guessed from the sound in the vid that you did.
I saw this when comparing window up to window down when tuft testing my Kammback mockup: http://ecomodder.com/forum/showthrea...sion-3518.html
Old 04-28-2009, 12:55 PM   #12 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Nope, windows closed. It's loud in the car without the carpet in.
Old 04-28-2009, 01:08 PM   #13 (permalink)
The rear angle looks to be roughly 14°. There is definitely a curvature to it though.
The picture doesn't look perfectly level though either. The front end is slightly higher than the back end (referencing the trim piece on the door). But, its only about half a degree. So, the rear taper is probably closer to 13.5°.
Old 04-28-2009, 01:18 PM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yep, the driveway isn't level, but I think it's only half a degree.
Old 04-28-2009, 02:21 PM   #15 (permalink)
Clear lexan boat-tail that doubles as extra storage and you're good to go
Old 04-28-2009, 02:27 PM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
O, I've got plans
Old 04-28-2009, 02:30 PM   #17 (permalink)
that's a nice crx, I'd have a hard time riviting things into it. Doesn't mean a nicely fit boat-tail that slides into a reciever hitch and a modified front bumper cover can't be done though
Old 04-28-2009, 02:31 PM   #18 (permalink)
Dartmouth 2010
SVOboy's Avatar
Exactly what I was thinking!
Old 04-28-2009, 03:41 PM   #19 (permalink)
Ah. Mine's louder with the rear seat out.
The other thing that will cause turbulence back there: side mirrors. I hear yours are not long for this world.
Old 04-29-2009, 02:02 AM   #20 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Thanks!
I used a spirit level with a scale and found the following:
  • 11 degrees - roof at junction with rear window mount/liner
  • 21 degrees - top glass near glass mount/liner
  • 28 degrees - middle of rear glass
  • 31 degrees - bottom of glass near junction with mount/liner
When I did my tuff testing, I only had a middle and lower region tuffted. I have to admit some surprise at the steepness. In fact, now I'm interested in seeing if I can measure the depth of this turbulent area.
I'll copy this data under my original tuff testing and continue the experiment. I have some loaner vortex generators coming and we'll get a chance to see the effect.
I also have a Kovatch "filter separator" pressure gauge that unfortunately has a scale that runs 0-30 psi when I need 0-30" of water. I'll have to modify the spring and calibrate it.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 11:51 AM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
2nd Gen CRX Passenger Side Mirror Block Off Plate SVOboy Aerodynamics 5 08-07-2008 01:21 PM
Video: tuft testing rear wheel skirts - Geo Metro MetroMPG Aerodynamics 6 07-11-2008 08:26 AM
