Old 07-26-2009, 06:23 AM   #31 (permalink)
blueflame's Avatar
Originally Posted by ConnClark View Post
Try modding a cold air intake. Diesels are more efficient with cold air. Also try and come up with a ram air intake. That will help a little too.
This paper below shows the correlation of intake temperatures and efficiency of a modern diesel engine. (see the graph at the bottom left of page 5)
http://www.buet.ac.bd/me/icme/icme20...ME05-TH-35.pdf
I had a good read there.
The test was done at 30-60 degrees C, 30 being better than 60.
I have no instrumentaion, but would hazard that cold air in Auckland NZ this time of year is about 8-12 degrees C and that the temp of my air after it has been heated on the exhaust manifold after passing throught the air filter and 2 plus feet of intake ducting would be about 30 degrees C, just going on holding in my hand the intake ducting near entry to the engine.
I feel the test condition need to be expanded to appreciate warmer air benefits in climates colder than 30 plus Degrees.
Old 07-26-2009, 10:35 AM   #32 (permalink)
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
The IAT's tested are in the correct range for the motor tested given ambient temp ranges going through the entire intake tract. I have a very similar motor and have monitored these temps before at various loads, temps, conditions, ect. Each motor may vary some in the temps they operate best so keep this in mind.
Old 09-15-2015, 12:58 PM   #33 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Granted@ em setting( this won't happen).
max boost can be pushed past the systems capacity to yield higher pressure. The increase in pressure is from heat 450°+iat.the same volume of air is pushed in just expanded (less efficient) to combat this problem an intercooler is used (larget than stock. Or more than one cool cooler.)
Increase iac=increased egt =Faster spin on turbo(expanded exost gas) this can snowball quickly into melted pistons.
My 91 dodge stock as Cummings built it.
I see this on long hills w/ac on my intercooler gets heat soaked from the condenser. I'll pick pu 100°-150°f on my egt meeter
@wot I. See the turbo lag on egt meeter egt will spike to1100°f and as pressure increases (engine leaning out) egt drops to 1000°f.
At idle(cold in park grid heater on)250°w/ac+25°
Idle (worm) 275°
Idle (cold hot in gear)300°
Compression breaking. 150-200° and 2 psi boost (reason over feeding o2 as stated by others leaner is colder)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
New here with 2006 Dodge Ram 2500 Turbo Diesel nubbzcummins Introductions 3 09-02-2010 01:35 AM
63mpg in a 1986 Isuzu Trooper Turbo Diesel TheWildHippie Success Stories 18 08-10-2010 11:40 AM
Diesel Power Magazine Fuel Economy Shootout JQmile EcoModding Central 3 03-18-2009 09:23 PM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 03:28 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
