Old 10-14-2012, 06:44 AM   #1 (permalink)
Toyota magnetic vss sensor help
Hello all,
I'm trying to fit my MPGuino and I've run into a snag.
The injector connection was a piece of cake but the VSS is proving tricky.
The automatic gearbox uses a 2 wire magnetic sensor and the 4 bolts on the propshaft as the trigger. From what I read the sensor produces 5V as the bolts pass across the magnet.
The MPGuino does not seem to like this signal. It works at higher speeds (over 20 - 30 km/h) although it seems a bit erratic.
Any assistance would be much appreciated.
Old 10-14-2012, 03:24 PM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You just need to amplify the signal and then MPGuino will cut it to 5V.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 10-14-2012, 03:31 PM   #3 (permalink)
Great, thanks for the response.
Sorry to be needy, but can you suggest a simple amplification circuit which will work?
Old 10-15-2012, 09:02 AM   #4 (permalink)
AndrzejM's Avatar
Something like this should work just fine.
The Following User Says Thank You to AndrzejM For This Useful Post:
ECONORAM (10-27-2012)
Old 10-20-2012, 11:19 AM   #5 (permalink)
the crazy guy in back
Cressy - '90 Toyota Cressida
Pickup - '91 Toyota Pickup base
Send a message via AIM to kamesama980
If the VSS in the transmission has 2 wires, it's a VR sensor, not a hall effect sensor. it produces a double sawtooth waveform with it's amplitute proportional to speed and proximity to the tone generating magnetics (in this case, the bolts) which is why the MPGuino doesn't see it at low speeds.
If you have a cable driven speedometer it's totally different and I'm in the process of figuring it out because that's how my truck is and my MPGuino doesn't like it.
Sme of the early ABS equipped cars as they get older, the wheel speed sensors start to lose sensetivity and cut out at low speed causing the ABS to kick on coming to a stop on dry pavement. Yours isn't a poor signal from age, it's just below the threshold of the MPGuino
-2003 Subaru Baja 2.5 5MT
-2005 Subaru Baja 2.5T 5MT
-1994 Pontiac Firebird 5.7 V8/6MT
-2001 BMW R1200c
-1970 VW Beetle
-2015 Prius (for the wife)
"You don't get to blame me for how I fix what you broke."
Old 10-20-2012, 05:50 PM   #6 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
I dont know what mpguino you have but it normally expects VSS input to be pulsed 12V.
If yours is 5V max, then you can probably change resistor(s) in VSS input (probably around 50K) to smaller value resistors (5K-10k maybe?)
My point is that instead amplify 5V to 12V you change resistors between VSS input pin and microprocessor (input to atmega can be 0-5V)
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 10-20-2012, 06:29 PM   #7 (permalink)
AndrzejM's Avatar
Changing resistor won't help if signal is below 5V, there is a Zener diode cutting the signal at this level, and resistor is cutting the current not voltage . So you need to amplify the signal.
Old 10-22-2012, 05:00 AM   #8 (permalink)
Thanks for the responses guys. Given the complexities of the mag sensor to MPGuino setup, I've decided to go a different direction and fit a reed switch to the back of my speedo, with a NE555 based debounce circuit.
I haven't refitted the dash yet, but early bench testing looks positive.
Old 10-22-2012, 05:06 AM   #9 (permalink)
AndrzejM's Avatar
That's cool! I'm hoping that will work for you flawlessly.
Old 10-23-2012, 07:41 PM   #10 (permalink)
Where would you put a reed switch???
Also, what year, make, model car is this. I have access to alldata and the half dozen or so non-cable driven speedo toyotas I've looked at all use 3 wire hall switch VSSs sensing a toothed wheel inside the transmission.
In other news, my cable driven speedo has a reed switch that grounds a 12v line from the ECU. IE 12v square wave.
-2001 BMW R1200c
-1970 VW Beetle
