Old 05-11-2009, 12:42 PM   #1 (permalink)
Source for new xA Final Drive and/or gears?
Hello,
I'm hoping to find a source and info on a better final drive for my 2005 Scion xA. It's a 5-speed manual with a 1.5L VVti engine, and the final drive is 4.31:1, and so even though both 4th and 5th gears are "overdrive" ratios, it still is only going 40mph in 5th gear at 2000RPM. At 55mph, it is turning at ~2500RPM and I would love to drop the RPM's ~20% down to 2000RPM.
This is the one imperfection with my local Toyota dealer (Acton Toyota, now in Littleton, MA) -- they do not have the info (inclination?) to find out what Yaris\Echo\Spectrum\xA\xB part(s) would be a bolt-in fix for me...can anybody here help me, please? Especially if you have done this on one of these Toyota vehicles.
Old 05-11-2009, 01:07 PM   #2 (permalink)
Do you know the transmission code for your car?
The Paseos run a C150 5 speed, and the Tercels run C141 (4 speed), and C150 (5 speed). All parts I believe are interchangeable. The 4 speed has the lowest differential @ 3.526. The only thing is, I'm not 100% sure that the 4 speed differential will fit a 5 speed transmission.
If you run a C5x transmission, you have a much larger gambit of transmissions to choose from as you'll share parts with the Corolla, Matrx, and MR2. However, in this family of transmissions, I know the 4 speed differential does not fit into a 5 speed housing. Still, there are a few transmissions you could take a 3.722 differential from.
Old 05-11-2009, 04:02 PM   #3 (permalink)
Hi,
It seems I might want to look for a (2004) Echo:
2004 Toyota Echo - Specs
All the transmission specs match, except for the final drive at 3.526 vs 4.31 which is ~17.5% taller, which would be just about perfect!
Old 05-12-2009, 04:43 AM   #4 (permalink)
...and sheet aluminum?
Another question:
Where would I buy sheet aluminum suitable for making and under pan?
Old 05-12-2009, 07:15 AM   #5 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
As far as I know, you could just swap a whole Echo transmission in-- it's basically the same, save for the final drive ratio.
Allegedly, the 9th-gen Corolla's 5th gear could be swapped in, and it's a somewhat taller ratio. I haven't heard of anyone doing that swap, but it's also in the C transmission family, so it is likely possible.
Old 05-14-2009, 02:48 AM   #6 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.61 mpg (US)
Neil,
Based on my experience driving an xA (you read my review) I think this would be a great mod for FE. However I wonder if using a much taller final drive like a 3.5x would make the car overly sluggish from a standing start due to the 1.5's relative lack of low end torque. Maybe you should test drive an '04 Echo with a 5 speed to get a feel for it before committing to the swap. Also keep in mind that your car is about 300 lbs heavier than the Echo.
Old 05-14-2009, 10:01 AM   #7 (permalink)
Hello,
Originally Posted by me View Post
Another question:
To answer my own question, I asked a friend who is building his own aluminum airplane from plans, and this is where he is buying all his aluminum stock:
Trident Metals-Locations-Boston Branch
Old 05-14-2009, 10:49 AM   #8 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Originally Posted by Formula413 View Post
Neil,
My buddy had an 04 Echo hatchback and it seemed to have lots of grunt in 1st and 2nd. We towed about 800-900lbs of fishing boat and trailer and even on the boat launch it did ok. Wind up a little wheelspin and up it went.
At 60mph steady it posted some pretty high mpg numbers on my scangauge, 54-60mpg if I recall right.
Anyways if you find a hatchback to try you might end up just trading in your xA for it...
Old 05-22-2009, 04:49 PM   #9 (permalink)
Boxhead
Toyota only just started selling the Yaris five-door in the US this year (the three-door was available from the start), and they only sold the Echo here as two- and four-door sedans, unfortunately. It's too bad, because the five-door versions of either model are the best-looking in the range, too.
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 8 09-19-2014 02:42 AM
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 12:32 PM
VX final drive swap: Who to believe? Cleft_Asunder EcoModding Central 28 01-28-2009 09:17 PM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
New: Ford mods their Super Duty pickups ... chin spoiler + final drive changes MetroMPG EcoModding Central 1 01-08-2008 01:32 PM
