View Poll Results: Should the US switch to metric units?
Yeah, ASAP!!
71 |
73.96% |
I dunno. Let me think about it.
7 |
7.29% |
Now why would anyone use the metric system?
18 |
18.75% |
05-02-2010, 02:41 AM
#81 (permalink)
Wannabe greenie
Originally Posted by MechEngVT
In my years in the workforce any calculations requiring notebook solutions I've always done in metric, even though my current company is rather stubborn about keeping US-sourced designs imperial.
That must suck having to cut a 2,438.4 mm board into thirds, then. My ruler comes out at a nice even 32 inches.
05-02-2010, 08:01 AM
#82 (permalink)
needs more cowbell
Originally Posted by tjts1
No, the American system is far superior. You just fail to understanding because you're in love with the number 10.
I think TJ is just messing around here  Everyone who uses base 10 numbers (numbers comprised of the digits 0 through 9), which is everyone, "loves" the number 10.
You would have to be a masochist to prefer to work in sae
You have to be a sadist to want to inflict it on any more generations
05-02-2010, 05:18 PM
#83 (permalink)
Basjoos Wannabe
Ya know, I might be in love with ten. I have ten fingers, ten toes, a family of ten (7 people and 3 dogs) and am about to celebrate my 10th wedding anniversary.
All joking aside though, a superior measuring system is one that can be easily used, therefore making accuracy easier to attain more consistently. Most people struggle with fractions and fractions are the cornerstone of the SAE system.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
05-02-2010, 05:53 PM
#84 (permalink)
Basjoos Wannabe
Originally Posted by Ford Man
Maybe you understand the metric system better than our current system. There are 2 pints in a quart. 16oz in a pint, 32oz in a quart.
See how easy it is to mess up?
05-02-2010, 07:01 PM
#85 (permalink)
...beats walking...
...the ancient Babylonians used base-60 (the basis for our 'minutes' and degrees).
...not many people that I know have ten fingers on one hand and six on the other (wink,wink).
Reason: corrected Mesopotamians to Babylonians
05-03-2010, 07:30 AM
#86 (permalink)
Mechanical Engineer
Originally Posted by Old Tele man
...the ancient Mesopotamians used base-60 (the basis for our 'minutes' and degrees).
But it is still a fully logical system using the fingers-counting methods, you just have to count each hand in a different method - a higher level concept. One hand has 6 states (closed fist, plus each of five digits), while the other has ten (five digits raised, then lowered). Difficult to explain, but I can see how it would work.
Splitting materials evenly is best done not by multiplying their widths by a fraction, but by placing a ruler diagonally across the material to a dimension easily divisible into a whole number by the number of pieces you want to wind up with. Your 96" sheet goes into thirds at 32". I don't know what metric-unit plywood sheets are produced at, but I would venture to guess it isn't an inch measurement. Probably either 2 or 2.5m. Splitting it has little to do with how easily or evenly the number divides as you can force it to divide evenly. If you have a 2.5m sheet to go into thirds is 833.33mm, but if you tilt the measure diagonally until it measures 2550mm and mark it at 850 and 1700 and strike a line across your marks using a square you have divided it into thirds nice and evenly.
05-03-2010, 08:17 AM
#87 (permalink)
needs more cowbell
Why do you bring up the messopotatoemans Tele?
05-03-2010, 10:13 AM
#88 (permalink)
...beats walking...
...first, mia culpa (Latin: my error), it was the Babylonians not the Mesopotamians
...now, my answer -- for three (3) distinct reasons:
1) they're no longer around, ie: extinct.
2) they made base-60 "work" for them, ie: it's doable.
3) I work with number systems and "history-of-numbers" provides understanding and insight, ie: because I can (ha,ha).
05-03-2010, 10:44 AM
#89 (permalink)
needs more cowbell
Do you mind if I put 1 and 2 in the correct chronological order?
1) they made base-60 "work" for them.
2) they're no longer around, ie: extinct.
05-03-2010, 02:59 PM
#90 (permalink)
...beats walking...
...because YOU can!
