04-18-2016, 01:33 PM
OCD Master EcoModder
Using balance weight clips for aero wheel covers?
Has anyone here tried using balance weight clips to hold aero wheel covers on the rims? I think if they can hold on a wheel weight they should hold a pizza pan or coroplast disk in place.
Of course, remove the weight first. Just use the clip. Wheel weights can be bought at Harbor Freight and probably at parts stores.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
04-18-2016, 10:21 PM
Geez. 74 people have looked at this but nobody has said a peep.
I guess it hasn't been tried yet - or whoever did, isn't talking.
Bump.
04-18-2016, 11:46 PM
I may go melt the lead off a wheel weight tomorrow to see if it would work. Great idea!
04-19-2016, 12:10 AM
they rotate onto the edge of the rim so you have to let them swivel a bit. Ask me how I know
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
04-19-2016, 01:47 PM
My guess is, they don't rotate till after you start driving? They look fine and then...
04-19-2016, 01:48 PM
as you hammer the wheel weight on it rotates a bit.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
04-19-2016, 02:55 PM
Ahhh, thanks.
Forewarned is forearmed. At least you can see the problem. Maybe use a BFH. Or a teeny tiny one. Or hold clip in place with ... no, not my finger.
04-19-2016, 09:43 PM
I'd get some small weights and play with them. After you remove the lead there is not much to work with, so it will be a fun little project to try.
2003 TDI Beetle
2002 TDI Beetle
04-20-2016, 04:03 PM
#9 (permalink)
THAT's what I'm talking about. delicate little stuff that ends up strong.
2003 TDI Beetle
2002 TDI Beetle
04-20-2016, 04:49 PM
#10 (permalink)
Spaced out...
If you are going to go through the trouble of welding a dzus fastener to tiny little wheel weight clip, why not get a real dzus kit, with matching covers and do it right? That way the wheel is balanced with the mounts and you have little worry about unbalanced wheels.
I would think the wheel weights clips would be too much hassle for road side flat tire repairs and if you forget to cut an access hole for the valve stem
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
