Old 07-04-2009, 12:34 AM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 27.11 mpg (US)
Using less fuel = More MPG? article I found
This one confused me... It says "Using less fuel tends to mean better gas mileage" This was on a "Daily Fuel Tip" website~~hmmm, does using less fuel only "tend" to mean better gas mileage, beside using more gas, to catch up to a semi, to in return gain tons of MPG or the pulse and glide? hahaha
Name:	wtf daily fuel tip.JPG
Old 07-04-2009, 01:37 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
No, it doesn't always mean that you'll get better gas mileage. What if you're using less diesel fuel? :P
No, seriously, though. The quote is way too ambiguous to actually call it true or false. You don't know when you're using less fuel, whether you're accelerating, braking, idling, etc... You can't even tell if you're moving while using less fuel, at all.
So basically, you could be using less fuel, but only when you're unloaded at idle sitting at a red light during the first 5 seconds of start up... which doesn't affect your fuel economy at all.
I would say, however, that the part of the article you're pointing out is more geared toward the average person (which no one in the world actually is, nor would they admit to it if they were.), meaning that they "dumbed in" the quote, so that Joe down the street could say "Hey, I understand that!".
It happens alot, sadly.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Interesting article: 110 mpg bio-d motorcycle conversion MetroMPG Motorcycles / Scooters 7 02-21-2011 02:39 PM
Fuel economy racing... with supercars.. sad MPG ebacherville The Lounge 5 07-02-2008 09:25 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
