Old 11-10-2014, 12:06 PM   #1 (permalink)
Guzzler - '05 Chevrolet Optra LS
90 day: 25.95 mpg (US)
CNG Tamed Guzzler - '05 Chevrolet Optra LS CNG
90 day: 26.87 mpg (US)
Puzzler - '05 Chevrolet Optra LS
90 day: 30.25 mpg (US)
Lightbulb Using MAP Sensor Voltage to Monitor Engine Load
Hello there
I am an electronics guy and vacuum gauges are hard to find where i live, I have a voltmeter i managed to connect a voltmeter to MAP sensor which measures pressure.
Can i use this as an experiment too monitor engine load (pressure is proportional to vacuum) and thats what vacuum gauges do, if i keep an eye on MAP voltage on the fly would it help me to drive engine at minimum load and in that way i could get fuel savings without spending NOTHING at all. Is it a viable IDEA ? if it works i could buy a bluetooth voltmeter and write an application on my mobile phone which has a gps to at least calculate instant load vs speed which i thing would directly relate to MPG. Please give your valuable feedback if i should take this path as this could lead to a very very economical solution to boost mpg, I THINK imho but what do u think??
Bil
Old 11-10-2014, 12:20 PM   #2 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Do you have an android phone?
You should get a obd2 Bluetooth dongle and torque app.
Old 11-10-2014, 12:36 PM   #3 (permalink)
I tried one Dongle but it did not work
I tried one dongle it did not work because the dongles does not provide a wide range of interfaces, my car has KWP2000 and probably would get working on Scanguage but its expensive to import here
Old 11-10-2014, 01:27 PM   #4 (permalink)
Yes, that should work just fine.
