Old 09-20-2021, 03:03 PM   #1 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
2022 Toyota Tundra Hybrid
It is official. The new Toyota Tundra will have a hybrid engine
A twin turbo V6 + 1 electric motor = 437 hp at 5,200 rpm and 583 lb-ft of torque 2,400 rpm. I'm a bit surprised they decided to use Ni-MH batteries but that is tried and true technology .
Fuel economy unknown at this time.
https://www.thedrive.com/news/42430/...urbo-hybrid-v6
The Following User Says Thank You to JSH For This Useful Post:
aerohead (09-29-2021)
Old 09-20-2021, 04:11 PM   #2 (permalink)
90 day: 29.78 mpg (US)
Curious if you had prior knowledge of this development, or rely on public information?
Also curious of the battery capacity, and why NiMh? As far as I know, that chemistry doesn't have a higher C rating for charging/discharging than lithium ion chemistries. I'd think ability to quickly charge/discharge would be among the primary characteristics of a small hybrid battery in a heavy truck.
Old 09-20-2021, 05:08 PM   #3 (permalink)
JSH
AKA - Jason
JSH's Avatar
I have no prior knowledge on Toyota and everything I post is based on public knowledge. I’m not going to get fired for sharing inside information even though my position gives me a lot of knowledge about my company’s future plans. (I know our product plans and GHG credit strategy for the next decade.)
My guess as to why Toyota is using Ni-MH.
1. It is cheap and they have decades of prior experience. Japanese companies tend to be conservative and go with what they know
2. Toyota has a joint venture with Panasonic that has multiple plants building Ni-MH batteries for hybrids. Production Capacity isn’t an issue.
3. It works. They’re don’t need real high discharge rates and with a truck space and weight isn’t an issue. This is a relatively mild hybrid with a single motor that generally is there to boost performance
The Following 2 Users Say Thank You to JSH For This Useful Post:
aerohead (09-29-2021), redpoint5 (09-20-2021)
Old 09-20-2021, 05:36 PM   #4 (permalink)
Quite surprising once we consider Toyota has been mostly into full-hybrids.
Old 09-20-2021, 05:59 PM   #5 (permalink)
Yeah, I'd like to see a Prius-like hybrid in the trucks. My assumption is that their eCVT hybrid tech could scale to larger vehicles. Perhaps buyers just wouldn't be happy with a truck that sounds and feels like the transmission is slipping.
Old 09-20-2021, 06:21 PM   #6 (permalink)
IIRC the Hino 300 had the HSD backed by an AMT in the hybrid versions.
Old 09-20-2021, 07:12 PM   #7 (permalink)
JSH
AKA - Jason
JSH's Avatar
The Hino 195H has a drivetrain very similar to this Tundra.
Originally Posted by Green Car Reports
Indeed, the Hino's hybrid uses a single 36-kilowatt (48-horsepower) electric motor mounted between the 210-hp 5-liter five-cylinder diesel engine and the six-speed automatic transmission.
That's quite different from the layout of the automotive Hybrid Synergy Drive system, which has two electric-motor generators and a planetary gear set to provide various combinations of engine and electric motor torque output and battery recharging during regenerative braking.
The engine puts out 440 lb-ft of torque, while the electric motor can produce 258 lb-ft on its own.
Still, the Hino's 1.9-kilowatt-hour nickel-metal-hydride battery pack is the same one used in the very low-volume Lexus LS 600h hybrid full-size luxury sedan. And just like the Prius, there's an "Eco" mode button in the cabin.
https://www.greencarreports.com/news...ino-195h-truck
https://www.hino.com/hino-trucks-hin...html#driveline
Old 09-20-2021, 07:32 PM   #8 (permalink)
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
I'm surprised as well.
Not only does NiMh lack behind LiIon in energy density, it is also far less efficient than LiIon as it has significant charging losses.
Meanwhile with LiIon we're talking about almost exclusively ohms losses, wich can be ridiculously small in normal use-cases, aka not switching between supercharger and dragstrip all the time
Old 09-20-2021, 07:39 PM   #9 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.85 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 31.02 mpg (US)
From the description it looks like Honda's IMA.
Strange choice, as Honda nowdays uses something similar to HSD, while IMAs does not prove significant economy.
(According to this community, Insight becomes more efficient when you remove IMA)
The Following User Says Thank You to alexshock For This Useful Post:
Old 09-20-2021, 07:41 PM   #10 (permalink)
alexshock's Avatar
Nimh is more friendly to extreme temperature conditions, both hot and cold. This makes this truck usable outside of California
The Following 2 Users Say Thank You to alexshock For This Useful Post:
Ecky (10-01-2021), Waspswatter (09-27-2021)
