Old 11-26-2016, 10:01 PM   #11 (permalink)
Growin a stash
I had no idea it could be this cheap. Might have to do this soon
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
Old 11-27-2016, 12:49 PM   #12 (permalink)
Originally Posted by vskid3 View Post
Because (at least on my Gen2 Prius) the cabin lights don't turn off automatically if a door is left open...
OK, from the context I thought you meant leaving the garage doors open.
Still, one of the first things I do when I get a car is to disable that switch that turns interior lights on when the door opens - thus ruining your night vision, and letting anyone outside see you. Not to mention allowing your battery to run down if you're careless :-)
The Following User Says Thank You to jamesqf For This Useful Post:
j12piprius (05-04-2018)
Old 01-10-2017, 04:44 PM   #13 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Off topic what's the charging efficiency on the prius plug in HV battery? I heard it was around 80% of the energy used for charging the car is actually put into the battery?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-12-2017, 01:18 PM   #14 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
I assume that LiFEPO4 battery had the motorcycle style battery attachment with the small box posts and a screw. What kind of cable ends did you use? I am thinking about a LiFEPO4 conversion for my car when the battery dies, and that would be very helpful information.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 11-22-2018, 12:05 AM   #15 (permalink)
Growin a stash
Bought one
Two years later, my lead-acid battery is about to be 5 years old. I'm pulling the trigger on a Christmas present for myself. Bioenno Power 12V, 500 CCA, 20-30 Ah "lead acid equivalent." 4.4 pound weight. The website says it can handle a brief spike to 625 CCA. I'll put a supercapacitor in parallel, if I have to...
https://www.bioennopower.com/collections/480-to-500-cca
With the BLACKFRIDAY promo code, it's 15% off, so my total cost will be $216. That's about the same as a high-end lead-acid battery, anyway. I'm very excited.
I'm currently googling whether I can charge this battery up with a power supply or if I should spend the extra $15 for a charger. I guess I can charge it with a power supply.
2024 Chevy Bolt
Previous:
Old 11-23-2018, 11:44 AM   #16 (permalink)
You can charge a LiFePO4 with an automatic digital charger on the "gel battery" settting.
ME_Andy (11-23-2018)
Old 11-23-2018, 03:07 PM   #17 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I've ordered a LiFePO4 battery for my Insight to put in parallel with supercaps and want to get some thoughts on protecting the battery from cold damage.
My initial idea was a large resistor to the battery so most of the starting current and subsequent charging would be to/from the caps, but the battery could still keep the caps charged and allow me to have lights or radio on for more than a minute before losing the ability to start the car. However, I had the idea of a large resistor just to dramatically slow charging in subzero weather, and maybe use a pair of diodes so it can discharge at full speed. Or, maybe a resistor in both directions but a higher impedance one in the charging direction.
Does charging at all at low temperature damage the battery, or is it rate dependent?
Old 11-23-2018, 04:33 PM   #18 (permalink)
90 day: 29.78 mpg (US)
From what I've read, it is rate dependent, with the battery being much less tolerant of accepting a charge when below freezing. That said, I don't really have much experience with that, and I don't know to what degree it damages the battery.
I've thought of using high power diodes and allowing full current discharge, with a resistor in series for the charge side. There would be a voltage drop though. For that reason I'm inclined to use a single resistor to limit charge/discharge.
Ecky (11-23-2018)
