Old 06-26-2008, 02:20 PM   #11 (permalink)
Hello,
Originally Posted by bryn View Post
i could idle in a lower gear but its a 3.8 liter engine lots of gas just to do that
On a lot of cars, downshifting shuts off the fuel to the engine.
Old 06-26-2008, 02:29 PM   #12 (permalink)
90 day: 51.82 mpg (US)
If you're forced to ride the brakes to keep your speed in check, I'd be inclined (pun intended!) to see whether or not you're within the engine's fuel cut-off zone first.
I've seen vac tanks added to EVs - they don't have to be as giant as a propane tank. People have used DIY sections of capped PVC pipe plumbed into the system.
Lastly, bryn, you should add your car to the garage so we know what you're talking about (it'll appear under your username in every post): Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Old 06-26-2008, 03:15 PM   #13 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
any way to check if fuel is shut off? or maybe I should just add a manual switch for the fuel pump?
Old 06-26-2008, 05:07 PM   #14 (permalink)
ttoyoda's Avatar
This is for a manual transmission, I have not driven auto for 22 years so...
While coasting downhill, turn the key off, (your steering wheel will be locked so Danger, Will Robinson), was there a change? Turn ignition on (only to run, no starter motor, I am ass-u-ming the engine restarts from the auto trans drag). Was there a change? If you sense a change, the injectors were on during normal downhill coasting. In my cars, they are on. I would suggest turning off ignition with a switch rather than fuel pump, because that way you will not have the delay of re-pressureizing the fuel system on restart.
I agree with you about the size, I happen to have a lot of propane tanks around, and I made a tool to remove the valve, plus they are already threaded, they are free, etc. So whenever some one says "tank" I always think propane tank.
Woo Vacuum Pump! trebuchet03 The Lounge 10 05-14-2010 12:52 PM
Fiberglass or vacuum molded grill plug? JJW DIY / How-to 2 06-10-2008 01:12 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Brakes, EOC (engine off coasting) and reserve vacuum Lazarus Hypermiling / EcoDriver's Ed 5 01-24-2008 08:17 PM
ABS Brakes Saved Me Today DifferentPointofView The Lounge 7 01-15-2008 08:20 PM
