Old 06-03-2010, 08:49 PM   #1 (permalink)
Alexa - '07 Honda Civic LX
90 day: 38.32 mpg (US)
FX - '06 Infiniti FX35
90 day: 17.98 mpg (US)
Priya - '03 Saturn Ion 3
90 day: 27.81 mpg (US)
ScanGauge II not reading fuel cutoff
it does work but if i change any of the 4 gauges it stops reading fuel cutoff. I know the 8th Gen Civics need the "LP" gauge up to read cutoff and its up but i dont know whats wrong. i have to reset the thing and re-do all my settings for the cutoff to start working again. Anyone know something i dont?
Old 06-03-2010, 09:09 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
There is a cutoff sensitivity setting (which I haven't used myself). I wonder if that's involved.
I know others have used it before - I'm sure someone will chime in.
Old 06-04-2010, 12:11 AM   #3 (permalink)
ojman873's Avatar
Accent1 - '07 Hyundai Accent GLS
90 day: 28.88 mpg (US)
Send a message via AIM to ojman873
On a similar note, some days mine reads fuel cutoff while on other days it doesn't. This is without changing any of the gauges...:/
Old 06-04-2010, 10:04 AM   #4 (permalink)
It's possible cutoff is determined by other factors (accessories, coolant temp etc).
I'm not being very helpful :P
Old 06-04-2010, 10:22 AM   #5 (permalink)
imported Appalachian
Yoda - '97 Toyota Corolla Base
90 day: 30.51 mpg (US)
She-Ra - '03 Honda Accord EX
90 day: 22.91 mpg (US)
Thor - '04 Toyota 4Runner SR5
90 day: 18.26 mpg (US)
ScanGauge displays 9999 Fuel cutoff while accelerating
2002 Nissan Xterra, V6 3.0, 5 speed manual
During my summer roadtrip I noticed that sometimes the ScanGauge would display 9999 mpg indicating fuel cutoff. The problem is, I was going uphill with the gas pedal pressed.
In regards to your issue:
1) Check the "LP" gauge on your ScanGauge: It needs to be in CLOSED mode
2) Check the "TPS" gauge: On some cars TPS needs to be 0 when the gas pedal is not pressed
3) In an automatic you might need to be going a certain speed before it will allow fuel cutoff
I hope this helps
Old 06-04-2010, 01:43 PM   #6 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
On my car foot off the accelerator TPS=9 and it does Fuel cutoff in 3,4,5 gear if RPM is high enough.
On scangauge in SETUP/FUEL/CUTOFF I say TPS=10 for cutoff and the scanguage shows cutoff (MPG=9999 and GPH=0). If I set the scanguage cutoff to TPS=9 it does not read it.
So my advice set scanguage to read cutoff at one TPS higher then foot off accelerator TPS.
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
ScanGauge II with X-Gauge: ecomodder price $149.95 smartzuuk Instrumentation 0 09-01-2009 02:07 AM
Touchy subject - Big Bang Theory (not the religious argument) robchalmers General Efficiency Discussion 11 08-26-2009 05:27 PM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
