Old 07-13-2019, 12:30 PM   #61 (permalink)
ideal
Originally Posted by Taylor95 View Post
Can you elaborate on what an ideal cooling system is?
I'm thinking about putting vents in the wheel wells too. This would improve airflow through the engine bay in addition to keeping my brakes cooler at lower speeds.
I think that venting the wheel wells might improve mpg slightly at highway speeds because my wheel wells are a high pressure area.
At the time Hucho wrote the second edition of his aerodynamic textbook in the late-1980s,the typical passenger car's cooling systems drag contribution was around 12% of the car's overall drag.
With a cooling system,like freebeard has shared,the drag portion is reduced to 2% of the overall drag.
And as freebeard also shared,on a land speed record streamliner at Bonneville,at transonic speed,you could take advantage of that Merideth effect,where the heat flux coming off the engine expands the air against compressed-ram-air,actually providing net thrust.
The trick with the extractor side of the equation,is expelling the air in such a way that it merges with the external body flow field at an identical velocity,and parallel to the body.A look at the 1978 Pininfarina CNR,'banana' car will illustrate such a setup.It took about $100,000 in wind tunnel time to 'tune' these vents for the lowest drag.
Taylor95 (07-19-2019)
Old 07-19-2019, 08:10 AM   #62 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Wow, that is a huge reduction in drag from heat extractors. I will take a look at this vehicle you mentioned.
Old 07-19-2019, 11:13 AM   #63 (permalink)
https://driventowrite.com/2015/09/18...mics-analysis/
I believe the discussion is about the vents at the front axle line.
ecomodder.com: The body shape of minimum drag
You can't be wise and in love at the same time. -- Bob Dylan
aerohead (07-20-2019)
Old 07-20-2019, 07:24 AM   #64 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I think a lot of gains are available to me in the front wheel wells, since my jeep is lifted
Aerodynamic fringe mods on a lifted Jeep are pretty futile
Sorry to burst that airbubble
The Following User Says Thank You to euromodder For This Useful Post:
slowmover (07-20-2019)
Old 07-20-2019, 07:28 AM   #65 (permalink)
euromodder's Avatar
Originally Posted by Vman455 View Post
I'll be curious to see what results you get; to my knowledge, no one on this forum has tried hood vents yet. I probably won't get around to them until later this summer if I do them at all.
Vekke did , Hucho style, on his Seat Cordoba
Old 07-20-2019, 10:10 AM   #66 (permalink)
Yup.
The baseline is usage. Not just miles, but cold starts. Getting down into this level of analysis is where the money is located. On-road mpg can be separated by highway or street. Percentage.
As a daily commute is likely, it will be the other uses where the money can be reduced (combining ALL errands into one trip, for example). Designing a trip loop for those places one nearly always goes.
Farthest point first (via highway preferably to hasten warmup) and then back to home without any left turns, etc.
Parking so as to ease exit with dead-minimal steering inputs.
Leaving early enough to avoid high traffic volume
Etc
For me this was also ZERO vehicle use on Sunday. Forgot something? Tough. Do a better job of planning. (It worked).
Old 07-20-2019, 11:20 AM   #67 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Function must lead form... else form has no purpose for existence
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
