Old 04-10-2008, 10:48 AM   #1 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Brake Specific Fuel Consumption: A Really Useful Concept
There's a very interesting article on BSFC over at Autospeed. It's a must read for anyone concerned about FE.
http://www.autospeed.com/cms/A_110216/article.html
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-10-2008, 01:45 PM   #2 (permalink)
Very good article. It cleared up a few things I had thought (and was wrong about).
Old 04-10-2008, 10:32 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Great find!
It seemed to explain quite a lot that remained unclear...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-11-2008, 10:52 AM   #4 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I have. Pulse & Glide is the best way to take advantage of BSFC.
Old 04-11-2008, 12:50 PM   #5 (permalink)
CVT transmissions are based on this concept.
Old 04-11-2008, 01:26 PM   #6 (permalink)
I just wish that manufactuers published this info! Its almost impossible to find BSFC charts for cars.
Old 04-11-2008, 03:37 PM   #7 (permalink)
Hypermiler
Wagons
I've been tempted to go out and make my own bsfc chart. Using the scangauge, do multiple runs on a flat level road. Start at 1000 rpm so and run up through the rpm range. One run at 5% throttle, one at 10%, etc... Rig up a video camera for review and chart out the Gallons / hour vs rpm.
or something like that...
Old 04-11-2008, 05:07 PM   #8 (permalink)
Hypermiler
Wagons
I used it to determine the optimum rpm and load for the pulse. I don't have a chart for my engine, but looking at several others, it seems that 1500-2000 rpm and about 3/4 throttle is the peak. That's what I use for the pulse part of my P&G. This way, when you do use the engine, it's at its best (lowest?) bsfc. And when you're not doing that, it's off.
It works, too. Grille block, tire pressure, scangauge, and P&G give me the numbers I have.
Old 04-11-2008, 10:04 PM   #9 (permalink)
90 day: 51.82 mpg (US)
I've changed my P&G technique since finding the BSFC map for my engine.
The little 3-cyl mill's peak efficiency is at a higher RPM than I'd been going to previously. It's basically centered just above 3k RPM, where I was aiming for low 2k range before. Makes for brisker acceleration.
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Motorcycle Fuel Consumption (gas mileage) guide ginni650 Motorcycles / Scooters 0 01-16-2008 06:57 AM
Illustrated: fuel consumption at higher speeds MetroMPG Hypermiling / EcoDriver's Ed 1 11-28-2007 06:58 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
