Old 09-22-2011, 05:46 PM   #111 (permalink)
Audi - '97 Audi A6 1.9 TDI
There will be Audi A2 1.2 TDI also ;]
Audi A6 TDi
VW Lupo 3L
Old 09-23-2011, 02:47 AM   #112 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by Arturasz View Post
Hello,
This Saturday will be eco rally. I will be participating with mine VW lupo. As far as I know route will be only ~200 km. What are your advice?
Maybe you can explain how to use pulse and glide. I read a lot about it but still can't understand how does it works, and what it will save. Of course during this eco rally i won't be using P/G, cause it can disturb mine 2,4 l / 100 average if I will be doing something wrong.
You should keep rev under 3000 rpm in a lupo. if rpm are under 2000 rpm almost nothing happens because the gearings are so tall. So put the car in manual mode in 4 gear. Pedal to the floor without kickdown. When the acceleration in starting to end put the gear lever back ne E/drive. Then just release the gas pedal and let the car roll. Car will automatically put the car to neutral. With stock lupo this works best on 75 push to 90 km/h. Aero is just so bad that on higher speeds its a no go. On lower speed this is the best way to move. Also is you are not feeling happy doing it all the time then just roll all downhills in neutral. But I guess you do that already .
With stock car I was able also to see better figures if I used push to 90 and then started to glide with load. With load I mean tried to keep the instant fuel gauge at 2 liter mark or under. This way the fuel gauge settlet to 2.4-2.5 l/100km. I also think this was more efficient way to travel in a stock lupo 3l. Now when I have better aero the P&G is better.
Good luck to your race.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-23-2011, 07:02 AM   #113 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Oops.
Disregard.
Old 09-23-2011, 03:45 PM   #114 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
VW Lupo 3L -->2L | Facebook
Today drived the car to the x-treme tuning show. I was able to see 2 liters @ 85 km/h speed behind a truck. That time I didint have any smooth hubcaps in place and only other rear fender skirt was in place.
No problems with heat, with 100mm cooling hole fully open. @ 120 km/h the intake temperatures were about 60 celsius and water did not rice even to 80 celsius. I might need some engine insulation like you suggested.
I try to upload also a video, but its uncertain that it will come through...
Old 09-23-2011, 04:37 PM   #115 (permalink)
euromodder's Avatar
I wonder what the reactions from the tuning-crowd will be
Old 09-24-2011, 01:09 AM   #116 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
http://www.youtube.com/user/TunekoLt.../0/fu034YbRfks
Heres the video
Old 09-24-2011, 03:13 AM   #117 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 44.13 mpg (US)
Loving the Lupo...it's so shiny ! Cool mods too.
Old 09-24-2011, 10:06 AM   #118 (permalink)
Mine Lupo results from today's rally - 150 km / 3.86 liters. No chances for Audi A2 ;]
Audi A6 TDi
VW Lupo 3L
Old 09-24-2011, 01:11 PM   #119 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
What was the races avg speed?
Girls seem to notice the car more often at the fair. Its little red car with shiny things . Maybe for the guys its still too standard lookind at the fairs.
Old 09-24-2011, 02:25 PM   #120 (permalink)
totally it took about 2h 50min, but this time iswith solving variuos tasks (counting doors at certain place, buying eco item in sum close or exact to 2.00 eur). Avg speed was about 68 km/h.
Audi A6 TDi
VW Lupo 3L
audi a2 3l 1.2 tdi, tuneko, vw lupo 3l.
