Old 10-24-2010, 08:56 PM   #1 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
2000 Fiat Dakota Quad Cab
Hi, all!
My name is Tom, and I own a 2000 Fiat (was Dodge) Dakota Quad Cab. I am looking to make it more fuel efficient, as it is my daily driver.
Old 10-24-2010, 08:56 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
I guess I need to post 5 threads before I can post pictures, so...
Old 10-24-2010, 08:57 PM   #3 (permalink)
MPGuino Supporter
t vago's Avatar
Three...
Old 10-24-2010, 08:57 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
Two...
Old 10-24-2010, 08:58 PM   #5 (permalink)
MPGuino Supporter
t vago's Avatar
One...
Old 10-24-2010, 09:01 PM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
Here is a picture of my handiwork to date. I started building this thing back on Columbus Day, and I got the inspiration from this very board.
Skeleton
Side view, right-hand side
Side view, front facing rear
Rear view
I used Owens-Corning FoamulaR 1 inch boards for the frame, and 1/4 inch FoamulaR sheeting for the skin. I got a gain of 1 MPG with it so far, and would have gotten more if I hadn't been so heavy with the gas foot.
I would like to coat it with something to protect it against the elements. Any ideas?
Old 10-24-2010, 10:03 PM   #7 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Yeah nice shape. Get some fiberglass cloth. a gallon kit of epoxy. Fiberglass , Epoxy , Composites, Carbon Fiber - U.S. Composites, Inc. or other supplier.
Lightly spray the pink board with super 77 spray and lay on a layer of dry fiberglass. I would do it in pieces. Mix your epoxy and paint it on the fiberglass cloth which is glued to the pink board. You can tell that the layer is wet out when the fiberglass cloth becomes clear. Use disposable brushes. Consider covering the wet layup with strips of rip stop nylon particularly over seams.
Once cured the rip stop can be peeled off and you have an ideal surface for a secondary layup.
I would do a single layer at a time to lessen warpage. Make sure that you have the fairing taped down. Duct tape is an excellent mold release.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
t vago (10-26-2010)
Old 10-25-2010, 10:48 AM   #8 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That's not bad as an intro !
It seems highly flexible, which of the Foamular products is it ?
The Following User Says Thank You to euromodder For This Useful Post:
t vago (10-26-2010)
Old 10-25-2010, 04:02 PM   #9 (permalink)
PSmodder lurker
Strong Daytona prototype/closed coupe genes. Their regulation wide windshields & high metal roll cages, instead of expensive composite tubs, necessitated cleaner fastback tapers.
Still, a very aggressive aero look. Nice.
The Following User Says Thank You to botsapper For This Useful Post:
t vago (10-26-2010)
Old 10-26-2010, 11:56 AM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
Thanks for all of the info and props. I will experiment with the fiberglass once I receive it.
The frame was made from 3 each Owens Corning FoamulaR F150 1" x 48" x 96" tongue and groove foam sheets. The skin was made from 1 each FoamulaR 1/4" by 48" by 50 foot fanfold foam sheeting. I still have some of each type of material left over (about 1/2 of the fanfold sheeting) left.
The fastback style was dictated mostly by the side shaping of the quad cab itself. I had originally planned for a cover that looked like what was in the Naval Post-Grad School paper I found on this board, but I then made a closer inspection of the sides of the cab, and discovered that the sides of the cab tapered inward at about a 20 degree angle. It was a bit of a challenge to get the correct shapes for the ribs, and I ended up using an Excel spreadsheet to calculate the rough width/height for each rib.
The Following 2 Users Say Thank You to t vago For This Useful Post:
bikin' Ed (10-27-2010), euromodder (10-26-2010)
aero, aerocap, bed, dakota, dodge
2000 Dakota aux fan problem Andy50 DIY / How-to 1 09-29-2010 11:46 AM
Some engineer types discuss ecomodding options for a 2004 quad cab Dodge 2500 pickup MetroMPG EcoModding Central 7 11-09-2009 11:30 PM
