Old 01-09-2014, 06:20 PM   #11 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Check your rubber stoppers for your clutch and brake light. Thy're $3 each at the dealer and wear out, causing the car to think the clutch or brakes are being applied. Either one will prevent lean burn (happened to me). To test, tap the side of the pedal pad while driving. The minor play will cause the pedal to move off the wear spot.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following 3 Users Say Thank You to Superfuelgero For This Useful Post:
California98Civic (01-09-2014), slownugly (01-09-2014), turbothrush (01-12-2014)
Old 01-09-2014, 07:45 PM   #12 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
Dude! You're a genious
Old 01-11-2014, 11:03 AM   #13 (permalink)
I know, and I'm modest too.
The part numbers are in my intro thread if you need them.
Old 01-11-2014, 02:18 PM   #14 (permalink)
Jakins's Avatar
Well I replaced the one stopper with a penny and the other one was super hard to reach but with them fixed it still doesn't work. I gotta do some more diagnostics
Old 01-11-2014, 05:04 PM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Nice: http://ecomodder.com/forum/showthrea...tml#post371711
You should link that in your signature file so more people notice it. I do that with my garage entry because I put a lot of info there.
james
Old 01-11-2014, 07:44 PM   #16 (permalink)
Jakins's Avatar
Edit. It did fix the problem!
Old 01-11-2014, 07:45 PM   #17 (permalink)
Great to hear, lay down some numbers for the team then.
James, not into advertising (car is a high enough theft risk), that's why no pictures either.
Old 01-11-2014, 10:55 PM   #18 (permalink)
Jakins's Avatar
I got 55 with her today. I might be swapping everything from my hx into a 4 door sedan very very soon. I'm pretty pumped.
Old 02-01-2014, 10:47 PM   #19 (permalink)
My shift light is not working, but it was. The check engine light is off when I crank the car, then after it warms up a little, it comes on. I unplugged the O2, then plugged it back up and the shift lamp flashed one time. I'm so confused as to why the check light doesn't come on from the moment the car is cranked.
Old 02-02-2014, 01:27 PM   #20 (permalink)
You should start your own thread.
Pull your codes, and we can go from there. Fyi, the O2 sensor isn't used (open loop) until the car has warmed up (then it uses a closed loop, feed back cycle).
