Old 07-24-2012, 09:48 PM   #11 (permalink)
94EGCoopey's Avatar
There's no difference between the clusters other then the cruise control is a shift light.
Old 07-24-2012, 11:40 PM   #12 (permalink)
OK, cool; I didn't know that! So knowing that I'm not sure if I'd rather have an operational c.c. light or upshift light...hmmmm.
As of now, I'd say maybe rather have the c.c. light.
Thanks for the response, but get back to work so I can see pics of your build!
Old 07-25-2012, 02:04 AM   #13 (permalink)
My non-turbo suburban has a power to weight ratio of over 40lb per Hp.
Thats not the problem, when I load up and tow the power to weight goes well over 50lb/hp then it really starts to drag.
Old 07-25-2012, 11:26 AM   #14 (permalink)
90 day: 57.73 mpg (US)
FYI, Matt, the former owner/admin of gassavers.org did a VX engine swap into a Civic sedan, but an even older year than yours, if I recall. If you dig around there you may find his build thread. I don't think he's around to answer quesitons any more though.
Also: I don't think he quite got it 100% done. He ended up getting the new car fever and bought a Fit instead.
Old 07-25-2012, 03:33 PM   #15 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Wow, 2 of these VX sedan builds going on at the same time? Very cool. I decided to go with an HX engine for mine or it would have been 3!
