Old 12-20-2011, 09:13 PM   #1 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
WAI on MAF?
I've got a 2000 Ford Focus ZX3 with the 2.0 DOHC engine. Then engine uses a MAF sensor and I was reading through people's results with WAIs and it seems like MAF sensor engines don't like WAIs as well as IAT systems. I was reading in the focusfanatics forums, and a lot of those guys swear that CAI's helped their MPG's.
Basically, does anybody have any idea what will work best? I'll probably end up testing WAI, CAI, and stock system because the intake system on the focus makes swapping out the systems very easy, but I'm just looking for insight from members of the forum.
Old 12-20-2011, 10:36 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Neither CAI nor WAI will make a significant mpg difference on a MAF system, based on my testing and that of Darrin at metrompg.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 12-21-2011, 07:25 AM   #3 (permalink)
HydroJim's Avatar
That's disappointing oh well. What do you think about restricting the airflow to cause the throttle to open more for the same amount of air? It seems counter intuitive to block the air flow, but it might work. What do you think?
Old 12-21-2011, 08:15 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
It might work. Try it, test it, and tell us what happens.
Darrell
Old 12-21-2011, 10:52 AM   #5 (permalink)
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
I am not sure blocking air would help. Generally you want more air for lower throttle input. Not higher throttle input with less air. Most computers determine injector pulse width by throttle opening, MAF/MAP input, and O2 sensor adjustment. It would likely cancel itself out, but if it does not, the computer will likely go to rich instead of lean in this instance.
Old 12-21-2011, 12:55 PM   #6 (permalink)
The airflow restriction will act just like a more-closed throttle, using more power to pull the air past the restriction. The WAI would probably be more effective...
-soD
