Old 02-10-2012, 11:59 AM   #1 (permalink)
Yotarolla - '06 Toyota Corolla ce
90 day: 45.15 mpg (US)
Nighthawk - '84 Honda 700s
Motorcycle
90 day: 56.23 mpg (US)
Wife's Camry - '10 Toyota Camry
90 day: 23.89 mpg (US)
warmer fuel?
I was reading an article that mentioned this: "the fuel line was insulated and heated so the gasoline entered the combustion chambers as lean vapor."
I hadn't heard that before. Anyone have experience with this?
Old 02-10-2012, 12:10 PM   #2 (permalink)
...beats walking...
...sounds like the prelude to "...vapor lock..." conditions.
Old 02-10-2012, 12:21 PM   #3 (permalink)
Motorcycle
Background info: this was a technique used to win the 1973 shell mpg competition. It was a modified opel, achieving 376 mpg at 30mph.
Old 02-10-2012, 12:52 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Link or it didn't happen!
Old 02-10-2012, 12:58 PM   #5 (permalink)
Motorcycle
Now that I have more than 5 posts, link...
Souped Down 1959 Opel T-1 Gets 376.59 mpg : TreeHugger
The Following User Says Thank You to k-vette For This Useful Post:
Olympiadis (02-10-2012)
Old 02-10-2012, 01:15 PM   #6 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Surfacant:
Surfactant - Wikipedia, the free encyclopedia
While it's technically not a surfacant, heat energy has a similar effect by lowering surface tension. This improves both atomization and vaporization.
Gasoline is made of a variety of hydrocarbon molecules with a mix of vaporization temps. Some of them do not flash vaporize until the temp reaches around 400*F. The problem is that many of the hydrocarbons will flash vaporize at temps well under 200*F, so that problems like vapor-lock will pop up unless contingency measures are taken against it.
The main point is that some heat does help, especially in situations where atomization or vaporization is poor. This is common with wet-flow induction systems (carburetor & TBI), and in very cold conditions.
A fuel system under high pressure can handle more heat, but don't forget about your fuel vapor recovery system. Heating the fuel can overwhelm the vapor control/recovery, so again contingency measures have to be taken to handle the extra vapor from the tank.
MPFI with the injector spraying on the back of the intake valves will show the least improvement from heating the fuel. That's not to say it doesn't work at all, but every system responds slightly differently, so you'd have to try it out and then decide if it's worth the trouble.
Old 02-10-2012, 01:20 PM   #7 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Olympiadis View Post
[B]
ummm you don't want to heat the tank just the lines to the injectors that way the is no effect on the vapor control/recovery system..
Old 02-10-2012, 01:49 PM   #8 (permalink)
The problem is for many fuel injected vehicles, they get fuel pressure off a common fuel rail maintained at X pressure. Any fuel not used gets returned back to tank from pressure regulator return line (which ends up being most of the fuel ).
So its hard to heat fuel after rail (between injector and fuel rail ) as there no room with injector mounted right into rail .
Honda does not use return line on fuel rail, they have pump and fuel regulator in gas tank and run constant fuel pressure over the whole load . So with only 1 fuel line to rail I could see this being warmed up a bit (water warmer off heater core line) but not sure how much this would help with modern injectors as noted in above posts .
Old 02-10-2012, 01:56 PM   #9 (permalink)
I believe all gasoline vehicles since OBDII (1996) have gotten rid of return style fuel systems. I believe the change came because it reduces evaporative emissions.
Old 02-10-2012, 02:17 PM   #10 (permalink)
Transonic Combustion | Ultra-high Efficiency Fuel Injection Systems
regards
Mech
