Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-24-2009, 08:53 PM   #1 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Water heater blankets - still worth it?
Hey guys.
I just replaced my old gas water heater with an "Energy Star" model (.62 efficiency rating.) Is it worth putting a blanket on this unit? The manual says that a blanket is not necessary, but acknowledges that some jurisdictions still require them. Would a blanket pay for itself in the 10 year lifetime of the water heater?
Also, I'm looking at reinsulating the pipes. Both the water heater and pipes are in an unfinished crawlspace. The temps get below freezing outside for most of the winter. Currently the pipes have that relatively thin slip-on insulating foam hanging on them, and I'd like to do it properly. Any suggestions?
Old 06-24-2009, 10:40 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
If you have a blanket, I'd use it. If not, I wouldn't buy one, but make something work.
As far as insulating your pipes, as long as it's warm out now, I'd be working on it for sure, otherwise you might just end up down there in the freezing temps replacing them.
You might also consider moving the whole setup, if you have the time/skills/money into a warmer part of the house?
Old 06-24-2009, 11:14 PM   #3 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Space is what's at the biggest premium. However, the water heater is in a section of the basement that has been separated from the rest with walls, so I've been considering just insulating that part of the basement. Also, the floor above is the bottom floor of the house, and that floor gets mighty cold in the winter. I'm considering installing insulation between the joists in the basement and sheetrocking that in.
Old 06-25-2009, 12:06 AM   #4 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
What's the water heater sitting on?
Old 06-25-2009, 12:12 AM   #5 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
It's on a concrete pad.
Old 06-25-2009, 08:25 AM   #6 (permalink)
I'd throw a blanket on it. They're cheap and you're talking about 10 years of wasted heat otherwise. Even if it doesn't help a ton, it sure is going to save you over 10 years.
Old 06-25-2009, 01:21 PM   #7 (permalink)
And stick wood blocks under it... concrete leeches heat. Better to have an airgap under it, I think. Or just a solid (large, thick) piece of wood.
Turning off electric hot water heater when not home? ZachUA Saving@Home 33 12-09-2009 09:51 AM
Time for New Hot Water Heater dremd Saving@Home 70 04-17-2009 04:31 PM
Water Heater Help trikkonceptz Saving@Home 15 03-11-2009 07:46 PM
Insulation for water heater saunders1313 Saving@Home 8 09-15-2008 07:57 PM
Solar Water heater extragoode EcoModding Central 5 03-31-2008 12:54 AM
