Old 09-07-2011, 01:46 PM   #11 (permalink)
Originally Posted by mcrews View Post
1500 sand paper???????
I call bs..............
you need to come to my house and PROVE IT!!!!!
(on my car
They make 3000 grit sandpaper. The car was a total loss that I bought at a salvage auction for $5800 and fixed for another $6000. It was close to $30k new and had 21k miles on the odometer. The repainted parts (roof was not painted) are now more smooth than the factory finish on the roof. I probably would not do the same thing to a new car, but on anything old or faded you would be amazed at how nice a job you can do of restoring the original paint.
All my vehicles, except the 1992 Ford truck, stay in my garage which makes the exterior finish stay in great shape. While I may not be able to quantify any real improvement in mileage my feeling is surface drag is much lower than an old oxidized faded finish. Even if not I would still do the same thing.
regards
Mech
Old 09-07-2011, 03:46 PM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Wax on!
(Weight penalty)
Wax off!
(Aero penalty)
Wax on!
(Weight penalty)
Wax off!
(Aero penalty)
Wax on!
(Weight penalty)
Wax off!
(Aero penalty)
Old 09-07-2011, 04:09 PM   #13 (permalink)
...beats walking...
Piwoslaw -- "Mr. Miyagi" would be proud!
Old 09-07-2011, 05:03 PM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Piwoslaw View Post
Wax on!
(Weight penalty... but leaves and dirt slip off)
Wax off!
(Aero penalty and weight penalty from leaves and dirt)
Wax on!
Wax off!
Wax on!
Wax off!
Old 09-07-2011, 11:30 PM   #15 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I found the positive part of the Hot Rod Magazine article to be more useful than the negative part.
Top 5 Easy Aero Mods That Almost Always Work
We pressed Eaker to give us clues about simple aero tricks for typical musclecars-stuff that will work nearly every time even without tunnel testing. The delta between Cd numbers is often referred to as "counts," or thousandths of a point, so the difference between a Cd of 0.250 and 0.200 is 50 counts. Eaker gave us some rough estimates on how many counts of Cd you might improve when these mods are applied to a typical older musclecar. Try these next time you're at the track.
Lower the ride height: "Dropping the car-front or rear-will always reduce drag." On our Camaro, raising the tail 1.5 inches changed the Cd from 0.201 to 0.227.Improvement: At least 20 counts per inch
As an example of trying things that are not necessarily legal, we flipped over our original spoiler and taped it to the middle of the decklid to find where the air was most sensitive. This was a loser. Instead, we found that the spoiler was best in the conventional location but that the shape and position of the outer side edges and trailing edge were very critical.
We did lots of hoodscoop testing with Harwood's scoop part numbers (left to right) 3161, 3164, and 3182 borrowed from Barnett Performance. We also tried our old 6-inch cowl hood and a bone-stock flat hood we borrowed from Camaro Specialty and taped all the scoops in place on that hood. All the scoops were swoopiest when extended back to the windshield. Believe it or not, the cowl and the PN 3182 aero scoop had the very same Cd as the flat hood, and the other two scoops were just 10 counts worse. Better yet, the ram-air of the aero scoop was estimated to give us 24 hp at 250 mph.
Block the grille: Eaker's tip is "Always get air around the car rather than through it." Stopping air from entering the grille has shown dragstrip e.t. reductions of a tenth or two even on 120-mph cars. This will also reduce front-end lift, and when the front end raises due to lift, drag increases even more. (Bonus tip: Stiff front springs can also help prevent front-end lift). Grille blockage is more effective on older cars than on newer ones with sealed radiator areas, and obviously, it can only be used for short-duration events due to reduced engine cooling.
Improvement: 15 to 30 counts of reduction in Cd and 50 to 100 counts in reduction of Cl
Add a front air dam: "You can usually get 90 percent there just by adding a dam straight down from the front bumper, just like the one on your Camaro." Even Bonneville guys ask us why we have that big barn door on the front of the car, but keeping air out from under the car both reduces drag and neutralizes lift for solid aero gains.
Improvement: 20 counts less drag, 50 less lift. The taller the car sits, the more important the air dam is.
Seal the back of the hood to the cowl: This is another area that's less critical on newer cars that are already well sealed. Cowl-induction hoods have a high-pressure area at the base of the hood. Air does not travel out the back of the hood; it is forced down into the engine compartment. That air must escape through the car, causing flow disruptions and drag.
Improvement: 10-20 counts less drag, 50 to 75 in lift
Remove the outside rearview mirrors: Factory mirrors hanging off the doors are almost always obstacles to airflow. The '94-up Chevy Impalas and Caprices are notable exceptions; on those cars, the Cd actually gets worse when you remove the mirrors.
Improvement: 10 to 20 counts of drag
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following 3 Users Say Thank You to SentraSE-R For This Useful Post:
California98Civic (09-08-2011), Cd (09-08-2011), larrybuck (09-08-2011)
Old 09-08-2011, 12:21 PM   #16 (permalink)
90 day: 19.36 mpg (US)
While I may not be able to quantify any real improvement in mileage my feeling is surface drag is much lower than an old oxidized faded finish. Even if not, I would still do the same thing.
I agree with this. A clean car that sheds dirt/water easily (and is easily cleaned topside and bottomside) is one where problems are more easily spotted. As in my above post, anything that causes dirt, bugs, rain, etc less chance to adhere to glass and metal make for better visibility and for being seen more easily.
If it also has the benefit of being a bit more slippery, then it's icing on the cake. It certainly has the benefit of maintaining a higher resale value.
The last few mpg on a 50-mpg car hardly show a cash benefit (where the expectation is 35-mpg EPA). It's no less ridiculous, in other words.
Old 02-27-2012, 05:02 AM   #17 (permalink)
airtabs.com
Old 02-27-2012, 07:27 AM   #18 (permalink)
Send a message via MSN to markweatherill
I waxed my car's tyres and noticed a significant reduction in rolling resistance.
Note: I didn't, of course! That would be stupid!!
Old 02-27-2012, 10:49 AM   #19 (permalink)
I think this thread belongs in the Unicorn Corral?
aerodynamics, wax, waxing
