Old 05-29-2012, 09:52 AM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by brent777 View Post
nice chart but the mythbusters test say i will get better mpg with out my tail gate
I would say: skip the tailgate stuff and proceed directly to more effective bed solutions.
Tailgate effects are also dependent on cab & box design - especially respective length of each - something Mythbusters probably didn't mention.
SAE has also studied this and concluded differently from Mythbusters. I wonder who does better science...
http://ecomodder.com/forum/showthrea...er-up-543.html
Old 05-29-2012, 12:15 PM   #12 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
The KA series of engines are awesome...keep the numbers coming and get yourself an ultragauge or scanguage. Well worth it!
The Following User Says Thank You to Neen For This Useful Post:
brent777 (05-30-2012)
Old 05-30-2012, 01:13 AM   #13 (permalink)
master modder
brent777's Avatar
ticker - '97 nissan d21 xe
Pickups
90 day: 27.06 mpg (US)
Send a message via Yahoo to brent777
they are!!!!!!!! mine has 300,000 miles on it!!! every one always talks highly of them! and i never get sick of hearing it!!!!
and ya a scanguage would rock lol
-its hard to have a fun life if you don't have fun in life-
Old 05-30-2012, 01:16 AM   #14 (permalink)
master modder
brent777's Avatar
Pickups
(PS: tailgate effects are also dependent on cab & box design - especially respective length of each - something Mythbusters probably didn't mention.)
true true and know they didnt and for the test they where useing a 2000ish ford f-150 my bed is smaller then that (5ft w 6ft L) i really didnt think of that so thank you
Old 06-06-2012, 11:46 PM   #15 (permalink)
master modder
brent777's Avatar
Pickups
Old 06-13-2012, 10:11 AM   #16 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
That's a moot point if you bend up about 6 sticks of EMT tubing, and skin it with something. an aeroshell kicks butt
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-13-2012, 05:13 PM   #17 (permalink)
Jenny - '02 Chevrolet Prizm Lsi
90 day: 31.45 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 25.27 mpg (US)
Exclamation
Originally Posted by vectorges View Post
Before you buy a new electric fan look at junkyards. Most FWD cars have them, and that is what most cars have been for the last 30 years. You should be able to get one close in size for $20.
The best electric fan IMO is from a 90's taurus. I have one in my ranger they come with a shroud attached and are 2 speeds so if you off road you can wire up high speed to a switch for when your stuck in the mud and spinning your tires.
As far as tailgate removal, it definitely varies model to model. My ranger gets about 2 mpg better without the tailgate but my 2011 Tacoma gets about a little less than 1mpg worse. Also, one of the best aero mods IMO that you can do to a truck is an underbelly tray. Cars, generally speaking, are mostly flat underneath due to there uni-body construction whereas trucks have a full frame so the floor pans are atleast 6 inches above the frame and the beds are even farther up while the axles, exhaust, spare tire, cross members, drivetrain, etc. hang down all producing drag. When I put my ranger back on the road it's one of the first things I'm going to do to it plus depending on what material you use they can be free or close to it
The Following User Says Thank You to BackroadBomber For This Useful Post:
brent777 (06-14-2012)
Old 06-13-2012, 05:54 PM   #18 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
what air pressure are you running in your tires? I have a 95 nissan 4x4 pickup and I get 26 mpg with 50 psi in tires. no other mods except coasting when possible.
The Following User Says Thank You to mikehallbackhoe For This Useful Post:
Old 06-14-2012, 04:09 AM   #19 (permalink)
master modder
brent777's Avatar
Pickups
in the front 44 psi max side wall in the back i have trailer tires 50 psi max side wall all 205/75/14's
better truck mpg, mod, mpg
