08-08-2009, 10:41 PM
#11 (permalink)
Also, your speedometer and odometer are off, but you probably knew that.
08-08-2009, 10:49 PM
#12 (permalink)
My Goal: 35 MPG All Day
OMG**********sigh**** from this change I realize that I should have kept those over sized tires! I got great gas mileage with them ;( and the whole time I thought they were making me get worst mileage >;(
08-08-2009, 10:56 PM
#13 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
It should only equate to a couple 1/10's anyway. Not enough to cry about.
So where are your air dam, wheel skirts, and belly pan? I bet no one would car jack you if you had all those on there. :P
08-08-2009, 11:01 PM
#14 (permalink)
Nothing to cry about? Lol I was beating my goals and I didn't even know it... AND the LRR tires I bought that I THOUGHT was giving me +1 mpg compared to the old tires actually get -1mpg.....
Don't get me wrong, I'm happy my 90 day went from 30.59 to 33 but erg... that just means I'm not going to be able to get those reading again unless I do something crazy like the airdam, wheel skirts, and belly pan your talking about
08-08-2009, 11:05 PM
#15 (permalink)
Less post - more build thread. MOAR NAO!!!
08-08-2009, 11:24 PM
#17 (permalink)
Originally Posted by cfg83
I have a gps but I already have gotten rid of those tires
08-08-2009, 11:30 PM
#18 (permalink)
Still a good idea to check and make sure, since the margin of error for some OEM's is up to 5% @ 60 MPH, or 3 MPH correction.
08-08-2009, 11:44 PM
#19 (permalink)
Pokémoderator
RandomFact314 -
Hrmmmmm, I apologize for not reading more closely. Even with the tires you have on now, I think you should do an odometer correction test to see if your odo is accurate.
If I were you I would :
1 - Do the GPS odometer correction test on your current setup. Let's say for the point of example that your odometer is incorrect by -1% in your disfavor.
2 - Instead of +10%, make it +9% to be "conservative" in your estimate (because you can't prove it with test data). My wife's GPS shows greater than 2.5%, but I only give myself a 2% credit. I do this to insure that my claimed benefits are well within the range of error.
3 - +9% + -1% = +8% Correction.
4 - Go over your fuel logs and add the data in. I put tons of info my "details" section of my fuel log :
Ignore high/low MPG, only look at AVERAGE MPG (Chevron;91 Octane;#1). 181168 miles on odometer. Tires are larger, so odometer is reading 2% less, hence +2% correction: 248.7 * 1.02 = 253.674
But that's just me. YYMV. (Your "You" May Vary)
CarloSW2
