Old 12-16-2009, 05:37 PM   #21 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
old dirty socks and cereal bowl.
haha. just kidding.
its a papered, whatver came with mr.gasket mini chrome air breathers, and its a boxer. dump sand in the intake it is just gonna spit it back out the bottom.
I intentionally ported two heads while on the engine and hardly took out the shavings...
the car uses no water through the crazy seasons now.
must be luck, all luck and nothing else...
I have indeed felt like saying "amen" around this old junk more than once....
Old 12-24-2009, 09:55 PM   #22 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
stock filters (whatevers on sale)
i dont use k&n because its expensive and it doesnt help mpg (good power tho)
but ive been curious about true flow foam filters for quite some time
havent tried it because of the price
Past Present Future?
Old 01-06-2010, 12:00 PM   #23 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Originally Posted by RH77 View Post
More or less the stock filter element with custom, temperature dependent, air sourcing is my choice. I tried K&N, but it yielded no advantage -- in fact the maintenance quite costly and the darn thing disintegrated (I know, there's a warranty, but I don't want another).
I have a straight pipe entering the airbox to draw warm air from the exhaust manifold. The disadvantage is a growl under high throttle input. Otherwise, the filtration rate is moot so the OEM paper replacement is just fine.
RH77
A growl under throttle input is a Disadvantage? Why's that? those teggy motors sound good
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Air filter saunders1313 Hypermiling / EcoDriver's Ed 32 07-03-2010 11:35 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Broken Air Filter Discovered RH77 Off-Topic Tech 2 07-03-2008 10:14 PM
