Old 06-11-2021, 02:45 AM   #11 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 15.29 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One 70% - '24 Hyundai Ioniq 5 SEL
90 day: 98.52 mpg (US)
Teal Force Two 90% - '24 Hyundai Ioniq 5 SEL
90 day: 111.09 mpg (US)
For Phil Knox. A Better Route Planner itinerary for a Chevy Bolt from Radium Springs, NM to Denton Texas with stops for charging. Speculation on what a boat tail would do for this car.
2019 Chevy Bolt Road Trip from Radium Spring, NM to Denton, TX
1: 1 h 18 min - 76 miles
Walmart 512 El Paso Elect A
30 minutes 51% to 79% 15.9 kWh
$4.73
2: 1 h 34 min - 112 miles
Days Inn Van Horn Elect A
38 minutes 10% to 63% 30.2 kWh
$6.00
3: 1 h 13 min - 112 miles
Sonic, Pecos Elect A
43 minutes 10% to 68% 33.1 kWh
$6.83
4: 1 h 28 min - 95 miles
Walmart Midland Elect A
47 minutes 10% to 72% 35.4 kWh
5: 1 h 35 min - 100 miles
Walmart Sweetwater Elect A
41 minutes 10% 67% 32.1 kWh
$6.58
6: 1 h 27 min - 100 miles
Walmart Eastland Elect A
57 minutes 10% 79% 39.4 kWh $9.20
7: 1 h 55 Min -128 miles
Charger at Denton, TX
14 hours 44 minutes -709 miles
$40.92
Split over two days. Stay overnight in
Midland, TX, and use a destination
charger?
$7.58
Without a Boat Tail X = 1.0 Using a Boat Tail X = 1.3
100% 80% 60% 100% 80% 60%
240 mi 192 mi 144 mi 312 mi 250 mi 187 mi
Old 06-11-2021, 10:06 AM   #12 (permalink)
How much do the numbers change when you charge to a higher percentage? Or is there a economy/performance gain at 70-80% ?
Old 06-11-2021, 10:32 AM   #13 (permalink)
90 day: 29.78 mpg (US)
Efficiency won't change based on state of charge really. The Bolt has a slow 54 kW charging capability under ideal conditions, and after 50% state of charge tapers even slower. Beyond 80% of charge the Bolt is practically trickle charging, so it's not worth the time to go beyond that.
Old 06-12-2021, 09:48 AM   #14 (permalink)
Duh. Called adsorption rate and not really efficient time wise. I was wondering if arriving at the next station with more or less charge affected that stop more noticeably other than linearly of charge time. There is a second knee in the adsorption area where current falls further and the charge time extends again. This is where I usually stop my charge since it takes an hour to gain only one more resting volt (1 mile extra range)
Old 06-12-2021, 11:20 AM   #15 (permalink)
Old 06-14-2021, 09:26 AM   #16 (permalink)
Yup right there at 1:50 small, but there. I'm kinda colorblind in these colors.
AND I was inquiring about the poster's reasoning for the 80%, not yours.
