Old 05-11-2023, 06:24 PM   #101 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The problem is that Mom is always telling my brother to put things in the garage and he either puts them right inside the door or on that table, so it could take an hour to clear off Mom's junk and look through my stuff.
Don't you have a shed that you could store your stuff in unmolested and sorted and arranged however you would like?
Old 05-12-2023, 10:00 AM   #102 (permalink)
One suspects Xist's brother would summarily and quickly defeat that measure. BTdt, moved on
Old 05-12-2023, 11:54 AM   #103 (permalink)
The shed that I keep emptying? That is against the back fence, which wouldn't work well with two rolling tool cabinets, jacks, jack stands, and other tools that don't fit in them when I fix my cars.
Old 05-14-2023, 02:37 AM   #104 (permalink)
My dowel pins arrived. I cannot find my intake and exhaust studs.
Some time after I woke up I checked Amazon and all that it would say was that my dowel pins were out for delivery, they would arrive by 2100. My brother asked to go to Walmart, we stopped to get the mail, and at 1600 my dowel pins were in the mailbox.
Cool. I was just going to Walmart. I would be back right away, you know, after driving 4.4 miles each way, and navigating a huge parking lot and store.
I spent a while setting up a folding table, organizing my tools, and setting up my phone on my tripod. Then I spent a few minutes installing the dowel pins and head gasket, spraying WD40 on the heads, and setting the head in place.
I don't know that this needs to be four steps, but I completed four steps today!
Also in the past two months!
73. It can be a little confusing figuring out which way the head gasket gets installed sometimes.
74. They're marked with an up this one is not that i can see but looking at the configuration on the engine block there really is only one way for this to go on and i believe it to be just like this.
75. Spray a little WD-40 around the tops of the pistons and the piston rings to help lubricate things on first startup.
76. Reinstall the dowel pins in the front and drop the new head gasket over it.
When I asked Mom if she had seen some studs she insisted that I have my brother help me look.
"He is a good finder!"
"When I can get him to try!"
I kept telling him to help me look and he kept trying to go back and watch television. I had not looked on my work table for the dowel pins, but the insane monkeys with whom I live always put junk on that.
I kept telling the younger one to look there and then to clear off the table.
I swear that every single time he removed something from the table I needed to say "Clear off the table!" again and he kept just knocking things off the table onto the floor--and into all of the junk on the floor.
Cool. I am sure there are important things in there I may never see again.
The old monkey stepped on the C9 Christmas lights I bought to keep her plants alive, so I needed to clean up glass.
She insisted they were LEDs, which they definitely weren't.
She finally admitted they got a little warm, but just barely.
C9 is the largest size!
The young monkey stepped on another one and I swear that I have shards of glass in my hands.
When he had the table mostly cleared off he started trying to move it and like everything else stupid he did today, I kept yelling at him to stop and he never slowed down.
Can you tell how grateful I am that Mom insisted I had him help?
Having him help invariably goes just as slow as soloing it, but with infinitely more yelling.
I found a bunch of screwdrivers, kept telling him to put everything but the screwdrivers in a box, kept telling him not to put the screwdrivers in the box, and apparently he snuck them in when I wasn't looking, so I needed to make him remove the screwdrivers.
I ran across some other tools that will be going in one of my toolboxes.
I recycled and threw away some more stuff, but I stopped well before we went through everything he knocked off the table, let alone the junk that was already under the table (and the stuff he knocked off the table into preexisting junk).
Then the corner is full of all kinds of junk.
Anyway, I found a new stud still in the bag.
It must have been one of the fasteners that I ordered for Chorizo, couldn't find, replaced, and then found, but it is nice to have a part number.
This fits every Honda made since 1984, including my 1987 Honda Prelude Si and my 1990 and 1999 Accords.
Norm Reeves Honda Vista sells them for $1.71, but I am tempted to go to a junkyard and pull all of the studs.
"Hey, do you have any Hondas."
"Sure, which ones?"
"Anything made since 1984."
Since this has been used on every Honda since I was 5 I am not worried about ensuring it is the right part, but I will probably need other parts, which probably have changed over the years.
Norm says it cannot find my VIN, although VehicleHistory didn't have a problem.
Norm kept saying I had an Si, so I manually selected my vehicle:
Enter my information?! You have it right there!
I put in the part number and it showed the original page, but didn't show where it goes on my car.
It also doesn't show my car anymore.
I went back to where it showed my car, searched for "intake manifold bolt," and it showed too many parts, so I searched for the manifold, and it only shows 2, the rest are bolts. 92900-08028-1B
There are 3 studs on the exhaust, but I needed to pull up the head to see that.
I clicked on the cart and it says it is empty.
I am not buying from this place!
It says $8.06 for 4 studs and $18.95 to ship, $27.67 total.
I am going to find the best price--or place that will ship it the fastest--but I am going to skip to tossing and turning.
I still feel depressed that I spent a ton of time and $800 building Mom a greenhouse and for 18 months all that she has done is complain about it, lie about giving me permission to build it, and yell at me to tear it down.
Then I tried to work on my 2002 Civic, spent all day searching and cleaning the garage, spent $15 on dowel pins, spent a good while setting up, and then after 3-4 minutes I needed to spend much longer putting away everything and order some more parts.
Also, Mom identifies as a severe diabetic, I bought her one of these to hide sweets from my brother for when she wakes up with low blood sugar, and then asked why she didn't put it away.
"Oh, he already figured it out!"
By the way, I found a dowel pin. I kept telling my brother to find the other one and he kept trying to watch Hallmark.
Who knows if I will ever see it again.
ID:	33791   Click image for larger version
Old 05-14-2023, 06:40 PM   #105 (permalink)
Acura Parts For Less will ship 4 studs between May 29 - May 31 for $15.82.
Majestic wants $16.71 and Bernardi asks $19.43.
When I drove Mom home from Church I saw that my jack was halfway down, so tomorrow morning I will jack it up by the jack point, remove the stands, move Chorizo, jack up the 2002 again, and support the oil pan again.
Oh heck!
Where is the bolt to secure the jack handle?!
I am giving Mom the best Mother's Day present of all.
I locked myself in my room.
Old 05-14-2023, 09:04 PM   #106 (permalink)
Somewhere North of $120 and change? That's valuable watch?
How about this?
search.brave.com/search?&q=side+cutting+can+opener
Every can you open (on the bottom) becomes a decoy it you glue the lid back on.
Old 05-14-2023, 10:03 PM   #107 (permalink)
I don't know about the watch and who hides a penny?!
True, but I am sure that if he sees a can of food in a weird place he will inspect it.
Human food, at least!
Do you think a can of pet food would work?!
I was thinking something like this: Instructables: Lamp Hidden Compartment
Now, the writer said to put your goods in a cloth bag in a sock so that it makes less noise.
I would expect the shifting weight to draw attention, too.
I am thinking that you build a container inside the lamp.
The easiest way to do that would be with Great Stuff!
I found some more studs in the garage today.
Some dealer said the new one and two more the same size don't fit the 2002.
It is supposed to have studs 3mm longer and some might be that size, but they and the long studs don't quite match the pictures on eBay, so I expect to pay $15, wait 15 days, and find out they are exactly the same.
Old 05-14-2023, 10:59 PM   #108 (permalink)
Back in the 1970s we had a section of wall in the kitchen covered with shingles.
One shingle only had one nail, and we lifted the shingle above it when we turned it asiide so the cedar didn't wear.
Inside was a luch-box sixed cavity. We left it open when we moved out
Xist (05-14-2023)
Old 05-14-2023, 11:26 PM   #109 (permalink)
After 5 years, I cannot handle Mom anymore. It seems like we rarely talk without arguing.
She left right when I was putting pancakes on plates for her and my brother, I finished the pancakes, walked to Church, moved her car to a handicapped spot, and ran the air conditioning until Church was supposed to get out, then held the door for her, and drove them home, I immediately changed, and locked myself in my room.
So, I am the root of all evil, but I am avoiding her so that we don't argue.
Oh no! I am the root of all evil! I just watched an episode of MacGyver without paying for it!
Do you see how bad I am?!
I complained to my sisters about Mom waking me, demanding breakfast, complaining that I was making breakfast, and then leaving just as the pancakes were ready.
One sister laughed at my message. The other one ignored me.
Then I complained that I have absolutely zero support, either they ignore me or they laugh at me. I asked "How hard is it to occasionally respond `Sorry, eh'?!"
"I am sorry that you don't feel that we support you" and then a bunch more words I didn't read because I made it clear they don't support me, people just don't like it when you call them out on being inconsiderate.
Something about asking what I wanted them to do.
She got upset when I didn't respond.
I wrote "Occasionally respond `Sorry, eh'" and she replied "I just don't know what you want from us!"
Seriously!
She claimed we were having a crisis, but I didn't want to talk about it.
1. Don't pretend this is all in my head.
2. Occasionally say "Sorry, eh."
Since they were as useless as ever I let them know that if I am accepted into graduate school, despite what Mom said, she doesn't have any intention of leaving Show Low, the other sister said "Woah, let's calm down!" and the other sister /reacted it because they are useless children who don't use their words.
Sure.
Let's not discuss Mom not moving with the only family member keeping her alive.
Let's let that slide.
A while later one of them shared this collection of poorly-photoshopped dad pictures: https://www.boredpanda.com/father-ph...enturewithdad/
I complained the dad was lazy with the photographed duct tape and my sister suggested maybe he used staples, too.
"Macgyver once stapled a bad guy to some sheets of plywood."
"Why do you know that?!"
Season 6 Episode 16: "There But For the Grace."
Old 05-15-2023, 08:08 AM   #110 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Sound like you are a 24/7 care giver. Not good! Find some me time.
Your sisters will be of little help. They are not interested in taking on any of it.
Find yourself a disinterest party to talk to. Yes, maybe a professional.
