Old 09-05-2012, 09:52 AM   #11 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
my F100 will idle along all day at around 12mph in top gear... i really need new gearing lol!
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 09-05-2012, 10:43 AM   #12 (permalink)
90 day: 57.73 mpg (US)
Originally Posted by stillsearching View Post
A related question if anyone has a comment - i'm wondering whether top gear is always the best possible efficiency for a vehicle at lower speeds, could going even slower in 4th achieve better mileage?
It is possible on some vehicles that the 2nd highest gear at a lower speed (than top gear's lowest non-lugging speed) will be more efficient.
It will depend on gearing & aerodynamics of the particular vehicle.
EG: from Honda Ridgeline MPG vs speed graph: fuel economy with & without cargo trailer ...
The leftmost 3 points on the graph are in the 2nd highest gear. Probably a function of the truck's relatively high aerodynamic drag (and the fact that it's an automatic transmission with a programmed speed-based shift point) that makes cruising in 4th at a lower speed slightly more efficient overall than top gear.
See more speed vs. fuel economy graphs: http://ecomodder.com/forum/showthrea...you-15182.html
stillsearching (09-06-2012)
Old 09-05-2012, 12:03 PM   #13 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
My car is more efficient in 4th for sure. The sweet spot seems to be between 1500 &2000 rpms 50&60 mph in 5th, 40&50 in 4th. When I accelerate its typicaly between1500 &2500.
Old 09-05-2012, 12:13 PM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
750 RPM and just under 40 MPH in double overdrive.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-06-2012, 08:28 AM   #15 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
700rpm 5th gear around 40km/h it's less than 25mph
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 09-06-2012, 07:39 PM   #16 (permalink)
Originally Posted by Sven7 View Post
If you look at BSFC charts, your engine's most efficient operating speed is likely not 1200rpm. Usually it's more around 1500-2000rpm at about 80% load. I can't say whether going 30mph in fifth gear is good for your engine (even if it's not lugging), but if you're going that speed you should probably be either accelerating through your best BSFC, or coasting in neutral. That is, if you're looking for the most fuel efficient way of driving.
My understanding is lugging is torsional vibration resonance, if you feel it its bad, if you dont feel it it's probably fine... if anyone knows that speeds shortly above lugging that you dont feel are damaging please tell me. :P
The original EPA figures were 29city for my car, the new ones something like 24 or 25 I think. I consistently get 29-30 around town. The tight traffic and angry drivers dont allow me to P&G around town without getting shot in the face. I don't know if the BSFC drop at 1200rpm is worse than running 2000rpm in 4th. Does anyone know where one could find BSFC maps of engines offhand? (if anyone had a repository i'd think ecomodders would :P)
You guys who are under 1000rpm, could you post engine details? I was trying to find engines without natural torsional resonances at those speeds in another thread and decided to try this different angle.. it seems to be a function of the engine itself and unchangeable.
Old 09-06-2012, 08:57 PM   #17 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Went down to 30mph in the Rabbit yesterday. It was pretty smooth but I didn't feel comfortable keeping it there. There are no problems using low RPM's because like most VW's it's pretty torquey- 1.7L 8V gas. I regularly accelerate in 2nd from idle speed, and 3rd at probably 500rpm or so.
Old 09-06-2012, 09:06 PM   #18 (permalink)
jalmir's Avatar
Avante - '02 Hyundai Elantra GT
90 day: 32.07 mpg (US)
My engine specs (accurate from other sources I can't find as fast) ;
Hyundai Beta engine - Wikipedia, the free encyclopedia
Old 09-06-2012, 11:49 PM   #19 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I realized today at 29mph I use 6th that low, at 6xx rpm. No lugging, bit if I go uphill at to high of a grade it will just start lugging and not performing. This is also when 5th is more efficient, 24-33 uphill.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 09-11-2012, 02:18 PM   #20 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Down to 18 MPH in 5th gear at 600 RPM without bucking. Level ground only.
The alternator does not keep up at that speed.
