03-18-2008, 01:00 PM
Geo owners
hey i have a 93 geo metro base, i know some of you have the same engine , transmission combos that i do and i usually run about 52-55 mph, and in good conditions, although many hills because i live in the mountains , i get about 55-60mpg, is this optimal mph? thanks
-Libby Metro
03-18-2008, 02:24 PM
50-60 mpg seems above average for most metros, nice  . Keep it up.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
03-18-2008, 02:46 PM
yeah i think i could get mid 60's but i have few oppurtunities for p&g here, not much flat ground , plus the roads suck, its a heck of a bump ride in a metro, i was going to try to find a civic hatchback shell and swap a vx motor in it , but recent financial strains have put that on hold
03-18-2008, 03:52 PM
I would get about the same mileage (55-60 MPG) on the highway if I did 50-mph in nice weather. That fuel economy would sink to about 36 MPG if I did 70-mph though.
03-18-2008, 04:10 PM
It's been so long since I've done a trip where I was just cruising (vs. P&G), I can't tell you for sure. But based on the speed vs. mpg chart I made, I would say 50-60 mpg @ 50-55 mph in good weather is reasonable:
Note - the green line was with the car in its "original" configuration - original cam & transmission.
03-18-2008, 04:44 PM
thank ya sir although im tempted to do the 70 mpg trip i cant stand to go that slow
03-19-2008, 12:17 PM
I keep it around 50-55. I will only hit above that when I'm setting myself up for a long EOC. It sound as if we live in similar situations, HILLS! Mostly down hill [20 miles] on the way to work, mostly up hill on the way back home. On the up hill, I frequently drop to 40ish. Steep hill.
I am not a Hippie...I am cheap.
03-20-2008, 12:00 PM
yeah its hard for me to do EOC here too much wildlife running out in front of me , i lose alot of FE that way, plus the blizzards cost me alot on the last fuel run, hours getting unstuck and what not, where do you live? Im in northwest montana
03-22-2008, 01:47 PM
#9 (permalink)
Twin Falls. ID...South Central Idaho... (Rolling Farmland)
