Old 04-27-2011, 03:43 PM   #11 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
1969 Chevrolet Corvette Stingray hood | Flickr - Photo Sharing!
This solution works also on todays cars. That cover pops out when you start wiping your windshield. You just have to make it yourself .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
JethroBodine (04-27-2011)
Old 05-01-2011, 05:05 PM   #12 (permalink)
daily transport - '00 vw golf tdi
90 day: 69.33 mpg (US)
windshield wipers
These wiper blades came with an offset bracket (approx 3/4 of an inch on centers). This allowed me to index my wiper arms down even further. When parked at the bottom of windshield they are almost completely out of the wind stream.
ID:	8274   Click image for larger version
ID:	8275   Click image for larger version
ID:	8276   Click image for larger version
Old 05-01-2011, 05:55 PM   #13 (permalink)
Originally Posted by orange4boy View Post
They reduce drag a bit depending on your windshield angle but they can reduce wind noise a lot. You probably can't measure the difference in drag with mpg's but the wind noise reduction can be nice. If you are driving on those lovely interstates paved with fist size rocks you won't notice either.
I have a 73 Dodge van and I pulled the park wire off the wiper motor about 35 years ago so I could stop the movement anywhere I wanted. Haven't a clue as to how you do it on these "newer" units.
My initial reason for doing it was simply to be able to easily park the wipers at about a 45-60 degree angle to hold a "frost shield". Later I started parking them verticially on road trips and it seemed to make a difference in some conditions in regards to wind noise and perhaps some mpg improvement but would not be able to verify that. Windshield really blows clear in the rain when this is combined with rain-x.
But not nearly as much wind noise reduction or mpg improvement as adjusting the big stock mirrors to a horizontal position (this is a very noticeable improvement and almost like a mirror delete by comparison to the stock speed brake mirrors.) I had small rectangular convex mirrors attached to the lower edge of the big mirrors and they were more than adequate when out on the highway.
Lost the sweet little convex mirrors recently and haven't found replacements.
Old 08-09-2011, 03:04 PM   #14 (permalink)
cool aero wiper setup
was walking down the street and saw this sitting there. noticed the cowl was a black plastic piece that was smooth and level with the windshield and the wipers park vertically along the pillars. i dont know what the make is im still looking.
Old 08-09-2011, 03:17 PM   #15 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
It looks like a Seat (Spanish automaker).
Old 08-13-2011, 12:50 PM   #16 (permalink)
If you'll use Search EcoModder above,for 'Flow-Images',in Photo-Gallery 3 at the bottom right is an image of the Jetta in the VW wind tunnel.The image is small (sorry),but if you look,you'll see that the air is basically passing over the wipers,not really touching them.
Quasimoto (08-13-2011)
Old 08-13-2011, 02:00 PM   #17 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
I have changed the wiper arms and blades on my focus to 'aero' flat blades with the wiper arms from a VW Polo (approx 2001 to 2005 years I think). They now sit well out of the airflow with only a small part of the arm visible when looking up the bonnet line.
Als this company Ford FOCUS 1998-2001 / 2001-2003 - JDL bonnet extension - www.jdltuning.com makes a bonnet extension that will fill the gap and direct airflow over the blades. Looking at the images though I think it may kick the airflow up at too high an angle for improved aero??
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
