Old 09-10-2008, 12:41 AM   #21 (permalink)
absolutely. all summer too.
Old 09-10-2008, 12:44 AM   #22 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
wouldn't cardboard under your hood be a fire hazard if it gets too hot? my dad yelled at me for that... I had some cardboard stuck half-in half-out to protect the wiring when I installed my DRLs.
Old 09-10-2008, 12:57 AM   #23 (permalink)
i've done this for over 10 years now and no cardboard or foam has gotten too hot. i like the foil-faced foam board, but it's too thick to work in my car.
Old 09-10-2008, 01:57 AM   #24 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Another option are those insulation blankets for water heaters modified to fit under the hood (which should tolerate high temps and have lower combustion risk). Block heater, insulated garage parking and grill blocking may be only other "quickie" solutions short of repainting your car to a darker color to facilitate faster warm ups.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-10-2008, 02:21 AM   #25 (permalink)
i dunno about that. i have my water heater wrapped and the wrap has a very light plastic cladding which i'm sure would melt and cause problems.
Old 09-10-2008, 11:21 AM   #26 (permalink)
Bucket - '94 Ford Escort Wagon
90 day: 36.46 mpg (US)
I was wondering about blankets, too. In the aviation world, our 540-cu-in (what's that, 8.8 liters?) air-cooled flat six engines don't like to start much below freezing, what with the weak starters and tiny batteries. And you do a world of hurt to them when you do, because the oiling systems on these engines also have significant weaknesses. So, for cold weather flying, you always 1) preheat below freezing, usually with a gas-fired heater blowing hot air over the engine, and 2) keep a blanket to cover the engine. If you're just shutting down for a little while (the $100 hamburger trip), the blanket will keep the engine warm enough to start right back up.
Used in conjunction with an engine heater of some sort, I think a mylar blanket on top of the hood might really help. Can anyone think of a downside? Not worried about scratching the paint, the car's 14 years old and looks it.
Old 09-10-2008, 11:58 AM   #27 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
You could use 1300L to attach it on the underside of the hood. Then you wouldn't have to remove/reinstall it every time.
(for you non-aviatin' types, 1300L is a thick yellow contact adhesive made by 3M. Also known as 'gorilla snot')
-Terry
Old 09-10-2008, 12:36 PM   #28 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Thanks for the tip Frank.
It was 45 F this morning here and my coolant temp hit just 150 F as I parked at work. I need to do something about this.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-10-2008, 01:53 PM   #29 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Sounds like you need a new thermostat. Or are you EOC alot? or driving very slowly a short distance?
Ian
Old 09-10-2008, 03:27 PM   #30 (permalink)
Ian
I drive a diesel, very lightly, for 7 miles.
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
make the car heavier to gain mileage?! bgd73 EcoModding Central 5 07-07-2008 06:33 PM
