03-19-2023, 12:51 PM
#31 (permalink)
I killed my wood chipper. Broke the fly wheel right off the engine.
03-19-2023, 02:59 PM
#32 (permalink)
Eco-ventor
03-20-2023, 09:52 PM
#33 (permalink)
Any idea why the flywheel broke?
03-20-2023, 11:59 PM
#34 (permalink)
Putting dry sticks in it.
03-21-2023, 08:30 AM
#35 (permalink)
That would be the prima facie version of the failure. I believe cRiPpLe_rOoStEr was inquiring about the actual breakage of the flywheel to crankshaft union.
03-21-2023, 02:39 PM
#36 (permalink)
Sheared a key or something?
.Two wrongs don't make a right, but three lefts do.
03-21-2023, 10:44 PM
#37 (permalink)
The flywheel assembly has been parted from the rest of the crank at the tapershaft nub. I destroyed it pretty good.
03-22-2023, 12:51 AM
#38 (permalink)
Makes me wonder if a belt coupling could prevented such damage.
03-22-2023, 01:33 PM
#39 (permalink)
I bet that's why the "commercial use" wood chipper has a belt drive. The new version is going to be belt driven with a 1.25 inch 4130 steel shafts turned down to a press fit 7/8 keyed shaft. It will have replaceable bearings.
03-24-2023, 12:39 AM
#40 (permalink)
Too bad you most likely can't (legally) get those horizontal-single either Yanmar or Kubota thumpers, which have built-in pulleys in the flywheel. Definitely boat-anchors, but they're indestructible.
