Old 05-17-2010, 07:31 AM   #1 (permalink)
90 day: 51.82 mpg (US)
Woohoo! "Reserved" myself a set of used Insight tires (Bridgestone Potenza RE92)
I've been on the lookout for a used set of 1st gen. Insight tires for a while now. (Why used? Because I don't drive much and any new set of tires I buy will die of dry rot before I ever wear them out, so it seems the fiscally prudent approach.)
I know of two people with 1st gen Insights. Inquired if they happened to have the right tires on their cars, and one owner sent me this pic last night:
He said to check with him in a year when he figured he'd be replacing them.
You know you're an EcoModder when... you get a little bit excited about a set of used LRR tires a year distant in your future.
Old 05-17-2010, 11:25 AM   #2 (permalink)
Atta boy!
Old 05-19-2010, 01:46 AM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Well, I can't say I ever plan on purchasing used tires, but it always happens that way. The only new tires I've ever bought have been when people replace them, then send the car to the junkyard without ever taking them off.
I pay $15 for the new tire and aluminum rim ($11 for tire and steel) and turn the rim back in to the recycling center for up to $15 = nearly free tire at times.
Old 05-21-2010, 09:29 AM   #4 (permalink)
I once asked a local yard about buying a set of almost new tires off a junked car, and they wouldn't sell them for liability reasons. Which seemed weird to me, considering all the other used junk they sell.
I wouldn't normally buy used tires either, but these are the Holy Grail of hard-to-find used tires . Also, it's not certain that I will actually have to pay for them.
Old 05-21-2010, 09:53 AM   #5 (permalink)
For future reference:
RE92 specs from Tire Rack:
Service Description: 78S SL, Low Rolling Resistance
UTQG (Uniform Tire Quality Grade): Treadwear 260, Traction: A, Temperature: B
Max Load: 937 lbs.
Max. Inflation Press: 44 psi
Tread Depth: 9/32"
Tire Weight: 13 lbs
Rim Width Range: 4.5-6"
Meas. Rim Width: 5"
Sect. Width: 6.5"
Tread Width: 5"
Overall Diam: 22.5"
Revs Per Mile: 926
Country of Origin "JP" = JAPANJP
Load Index 78 = 937lbs (425kg) per tire
Speed Rating “S” = 112mph (180kph)
Old 05-21-2010, 10:00 AM   #6 (permalink)
Looks like a set of OEM Suzuki 7-spoke 14 inch alloys + RE92 165's weighs a couple of pounds less than my current 13 inch steelies with 155/80's.
Have a line on the alloys... whether I go for them depends on shipping.
Old 05-21-2010, 10:08 AM   #7 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Lucky.
Old 05-21-2010, 11:58 AM   #8 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Are these the same RE92s that come as OEM on 05-09 subaru outbacks?
They get brought up a lot at the .org
They're known for hydroplaning more than anything over there.
But hey, low RR is low RR. It's a shame you can't use a subaru sized tire because most people get rid of them ASAP and probably would gladly hand them over if someone asked.
Old 05-21-2010, 12:09 PM   #9 (permalink)
They probably are the same. The RE92 is rated pretty bad on tirerack. But, I'd be willing to bet that if pumped up to max sidewall that the tendency to hydroplane goes away. Combine that with a hypermilers habits to not speed everywhere all the time and you actually have a pretty good/safe tire.
Old 05-21-2010, 02:51 PM   #10 (permalink)
I've actually inquired about this. In the US, that I can find, there is no *actual* liability issue with it. However, there's always some jerkoff lawyer that will eventually find a way to dick with the laws enough to hold someone else accountable for an operator's stupidity. It never fails.
So, in reality, it's not a liability problem. It's an "I don't want to eventually be held liable because of some stupid jerkoff's deep wallet and lack of intelligence." problem.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Full set of Potenza RE92 R14 - Toronto Area Wonderboy For Sale 5 05-25-2010 11:32 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
