Old 06-13-2012, 12:13 AM   #11 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Anything is possible...just because it is a small engine doesn't mean it can't guzzle:
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 06-13-2012, 01:24 AM   #12 (permalink)
Martha - '88 Honda CRX DX
90 day: 44.74 mpg (US)
Send a message via AIM to joat09 Send a message via MSN to joat09 Send a message via Yahoo to joat09
Pretty sure this would get about the worst gas mileage you could get out of one.
Old 06-13-2012, 11:26 AM   #13 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
So it's looking like 9:1 is the worst AF mixture you can have without flooding. With that being said does that translate straight into fuel consumption? In other words if ideal (stock) is for the most part 14.7:1 would a 9:1 A/F mixture be using 38% more fuel at any given time? Let's assume normal operation and look strictly at A/F ratios and not driving styles.
If the decrease in A/F ratio is more or less translated into fuel consumption then it looks like the worst fuel consumption in any given scenario is roughly 38%. Anything beyond that and it would have to be a fuel leak at that point. Does this sound correct?
Old 06-14-2012, 12:31 AM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
You'd have to figure the A/F ratio across RPM and appoximate VE to have any sort of an accurate figure.
9:1 at idle is a heck of a lot less fuel than 9:1 at 4,500 RPM @ WOT.
Old 06-14-2012, 08:40 AM   #15 (permalink)
How about 1.5 liter at 2 MPG.
regards
Mech
Old 06-14-2012, 11:35 AM   #16 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Enough speculation & WAGs. Here's a 1998 DX averaging 14.2 mpg, and another 1998 averaging 19.4 mpg. Just to show those two aren't quirks (they're only 3 tanks apiece), here's a South African who's only averaging 16.9 mpg over 1650 recent miles in a 1999 Civic.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 06-14-2012, 12:24 PM   #17 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
I don't mean to sound sexist but many of us with wives can answer the driving style part with the same car as an example. My wife consistently gets 24 mpg tank after tank in her 99 Integra auto. I drove her car on a 75 mile each way trip last year and averaged 47 MPG (per SGII) mixed highway and highway stop and go traffic. (no engine off coasting) note: I did anger other drivers by leaving more than 3 feet between me and the car infront.
Old 06-14-2012, 01:19 PM   #18 (permalink)
Yep I get that...but the difference between 9:1 and 14:1 should be constant at any given RPM or load condition correct? Such as 9:1 at 4500rpm at WOT is ~140% of the fuel consumption of 14:1 at 4500rpm at WOT right?
If someone came to this forum and was like; "I used to get 30 mpg now I'm getting 15 mpg. I'm driving the same and I don't see any leaking fuel, do you think my plug wires need replacing?"
We can say, "Hold up man/woman...chances are you have an external fuel leak that you are not detecting cause your engine wouldn't even run if you doubled the fuel amount into the cylinders. You better start at the tank and move forward looking for a leak."
So I was wondering if A/F ratio on average would translate directly into fuel consumption with all other variables being constant...I'm guessing it does. This will help me troubleshoot my own cars in the future...thanks for the feedback!
Old 06-14-2012, 06:10 PM   #19 (permalink)
In that case, yes.
Old 06-15-2012, 02:55 AM   #20 (permalink)
I'm a mechanic. I get cars in all the time with drivability issues.
First question: Is the check engine light on?
Second question" What do you get for MPG?
the first can be a bunch fo stupid stuff which won't affect mileage, or it can be a BIG problem which really messes it up.
The second gives a hint. From there, the scan gauge, possibly a ride around the block with the customer driving, and I can usually figure out what is wrong
