Old 08-15-2008, 08:12 AM   #1 (permalink)
Roman's Avatar
Golf D - '83 Volkswagen Golf GL
90 day: 42.79 mpg (US)
Adding Spoiler to Swift/Metro for FE
I just read the article about the Ford Pinto they modded back in 1974. That one on the main page. So they added a small spoiler. This saves 7%. The pinto and the Swift/Metro have (almost) the same shape. SO i was sondering will a spoiler also give a better FE to a Swift/Metro?
This looks to be easy installed. Little bit metal "L"-shaped profile and some scru's (and some paint).
NOW INTERACTIVE! Joystick controls Fry's left ear.
Old 08-15-2008, 08:39 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
The hatchback angle & design is quite different between the two cars:
The Pinto likely has attached flow partway down the glass, whereas the Swift hatch is actually designed to ensure the airflow separates as it leaves the roof line.
You'd be better off extending the Swift's roof line. EG: http://ecomodder.com/forum/showthrea...sion-3518.html
The 2.3% measured benefit of the prototype kammback isn't as large, but the testing was done at 55 mph vs. 70 mph for the Pinto. The kammback's benefit would be greater at higher speeds.
Old 08-15-2008, 01:16 PM   #3 (permalink)
JJW
The Crimson Jellybean - '08 Toyota Yaris
90 day: 41.8 mpg (US)
White's Elephant (in Black) - '02 Jeep Wrangler Sahara
I agree entirely with MetroMPG. If you notice, your swift/metro has a small "duck bill" buldge above the rear window which serves as a mini-spoiler, detaching flow from the rear window (where it would never stay attached at it's steep angle). I experimented with a few home-made spoilers on my old Metro and they had absolutely no effect.
Now, extending the roof line, I never tried.
Old 08-16-2008, 01:53 PM   #4 (permalink)
spoiler
Follow MetroMPG's lead,you won't go wrong.
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
aero-mods ( installment#8-INDUCED-DRAG(spoilers/lips/flaps) aerohead Aerodynamics 12 12-04-2012 06:19 PM
Anyone think this DIY lip spoiler is worth the trouble? bkrell Aerodynamics 4 05-25-2008 12:33 PM
