Old 07-31-2010, 11:37 AM   #1 (permalink)
New Chevy Aveo 2010
Hey guys. New to this website.
Bought a 2010 Chevrolet Aveo, it is manual, and does not have cruise control.
Pretty good gas mileage I would say, but I'm not used to great gas mileage. My summer car is a 2009 Cobalt SS Turbo (modded), and when in boost, that thing can really suck the gas.
I would like a few tips on how to improve my gas mileage from my aveo. Where do I start?
2010 Chevrolet Aveo
Old 07-31-2010, 01:30 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'd start by applying some of the Hypermiling tricks.
As it's a new car, you're probably not going to mod it right away, and there's a lot of fuel economy (FE) to be gained by changing your driving style and habits.
I went from 39.2 mpg in the first year to 42.8 mpg the past (5th) year - an 8.3% change for the better - simply by :
- driving slower (65 mph max.) on motorway / interstate / highway
- having low rolling resistance tyres (LRR) fitted and inflated above the car's indicated psi
- subtly changed driving habits.
Some of these techniques are pretty involved, bordering on the extreme, but some are very easy, like parking ready to drive away without manoeuvring.
Inflating your tyres above the psi indicated by the car manufacturer is also an easy, reversible mod.
Going up in 2 psi steps won't upset anything - and can easily be undone if you don't like the car's new behaviour - but stay below the tyre manufacturer's upper limit !
I've recently started to try other hypermiling techniques like coasting - and it seems to have an effect.
It's just a matter of trying some techniques, and see if it'll work for you in your driving environment.
Have fun
Old 07-31-2010, 04:27 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to EcoModder
Don't forget to start logging your fuel economy in the garage!
Old 07-31-2010, 11:50 PM   #4 (permalink)
I've got a 2009 Aveo with A/T and it really sucks gas at speeds below 45 MPH, due to the way GM programmed the transmission control module. Not much anyone can do except complain to GM about it.
Lucky for you, yours is a manual. I'd say throw it out of gear and coast as much as possible when practicable. You have the capability of doing that and clutching it back into the appropriate gear at any speed at will, whereas with an automatic tranny, shifting into neutral and back into drive at higher speeds would be inviting transmission failure.
Chevy Aveo: How to improve CITY MPG? Thymeclock EcoModding Central 20 06-24-2011 10:48 PM
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 04:39 PM
A fuel efficient car from GM for 2010: Chevy Spark bbjsw10 General Efficiency Discussion 21 03-17-2009 06:50 PM
Chevy Aveo second hand value up +9.3%, Expedition down -12.2% MetroMPG General Efficiency Discussion 2 07-29-2008 12:37 PM
